BrianG Posted June 1, 2007 Posted June 1, 2007 Minor details........... I finally fired up the 2000 V-11 Sport after relpacing the clutch and re-sealing the transmission. There is no neutral indication anywhere through the gear selections. The indicator worked at disassembly (big surprize!!) I tested the indicator system by taking the neurtal switch lead, at the transmission, to ground. Green "N " came on. Road test reveals normal non-neutral) start-up (with clutch lever pulled and kickstand retracted) and normal non-neutral kick-stand kill. Neutral is found between 1st and 2nd like it should be. Riding reveals all 6 gears available. So, the question is....... did I mis-assemble something inside the transmission or did I somehow kill the neutral-indicator switch?
docc Posted June 1, 2007 Posted June 1, 2007 Indeed, it sounds like a dead switch. Try removing it and cleaning/cycling it a few times to rescusitate it.
BrianG Posted June 2, 2007 Author Posted June 2, 2007 Good call docc....... intermittent closed. Cleaned it up with contact cleaner and it got better. Ordered new one!
