Took off factory exhaust cans on my 02 LeMans, replacing with M4's or Mistrails simply for weight & appearance reasons.
Must the bike be reprogrammed? or will it run fine as is with the new canisters? :doh:
Thanks in advance...
It'll probably run better with the new cannisters. :thumbsup:
Yep, thats right, l fitted Mistrals, it goes great, and sounds the way it should!!
:bier:
Cheers
Van
Mine ran worse when I fitted Mistrals until I also fitted a Powercommander - it lost torque (subjectively), and generally felt rough at low revs. Not so bad when ridden hard, but a bit of a pain around town. The Powercommander sorted it out (it now feels great), and Mistrals do sound lovely (not ridiculously noisy, but hang on to your originals for MOT time!). I guess the answer is probably that every bike is different, so you might just have to fit them and see - but be prepared for the possibility that you might need to spend more money sorting out the injection.
Hi Crooz
See Moscowphil's comments - I can echo that.
A PC-III will be an improvement and by using this little gadget you can tweak the engine to (aaaalmoooost) avoiding the flat spot around 3.000 RPMs. A Dynotest - at least in Denmark - is not that expensive so my advice is to cough up with the dole and take the entire Mistral + Dyno package.
Just tell your girlfriend/wife that this will make you a happier man! :P
Cheers
Søren
