droydx Posted June 7, 2007 Posted June 7, 2007 Can anyone confirm or deny that the turnsignal lenses for an 2003 VII and a 2003 Mille are the same units? I have a friend who has some clear Aprillia Mille lenes and would like to add these to my Rosso Corsa, if they are the same units. I recall that the VII units are the same as a couple other bikes.....just can't remember which bikes they are. Thanks! Andy
mdude Posted June 7, 2007 Posted June 7, 2007 Can anyone confirm or deny that the turnsignal lenses for an 2003 VII and a 2003 Mille are the same units? I have a friend who has some clear Aprillia Mille lenes and would like to add these to my Rosso Corsa, if they are the same units. I recall that the VII units are the same as a couple other bikes.....just can't remember which bikes they are. Thanks! Andy Buell indicators/lenses are similar, according to earlier threads.
stogieBill Posted June 7, 2007 Posted June 7, 2007 Buell indicators/lenses are similar, according to earlier threads. Buell indicator/lenses are THE SAME. Made in mother Italy, but sold cheaper through a Harley dealership..
droydx Posted June 7, 2007 Author Posted June 7, 2007 Buell indicator/lenses are THE SAME. Made in mother Italy, but sold cheaper through a Harley dealership.. OK, so they XBR9-12 Buell turnsignals. Thanks. Now I just need to find a source that sells the lens' on the internet. Anyone have a source? My local Harley shops won't touch a Buell, and the closest Dealer is about 50 miles away. Andy
tomsp Posted June 9, 2007 Posted June 9, 2007 2003 V11 is the same as the 2005 ducati ss 1000 ds - as I put on a set from my ducati -- exact
Guest ratchethack Posted June 9, 2007 Posted June 9, 2007 FWIW, a couple years back I picked up a complete Piaggio scooter turn signal assembly that was IDENTICAL to the MG stocker for about $10 USD (IIRC) at the local scooter dealer.
Guest h8chains Posted July 22, 2007 Posted July 22, 2007 Thanks for everyone's input. Just broke the front right yesterday.
DeBenGuzzi Posted July 23, 2007 Posted July 23, 2007 2003 V11 is the same as the 2005 ducati ss 1000 ds - as I put on a set from my ducati -- exact psh coulda paid 6 at HD, you got screwed if they weren't so cheap and readily available I'd just send you one.
Greg Field Posted July 23, 2007 Posted July 23, 2007 All the Buell turn signals I've seen look the same as the Guzzi ones but mount via an integral hollow stud through which the wiring is routed. The Guzzi and Aprilia versions lack this stud and are affixed to the bike via a screw inserted through the weak plastic tab at the aft end of the stalk's mouning pad. As a result, the Aprilia signals are a direct bolt-on to a Guzzi. Buell signals often require that the bike's signal mounts be drilled for passage of the mounting stud.
