Shawn Stepper Posted June 20, 2007 Share Posted June 20, 2007 Can anyone tell me what is causing this leak? Right in the center of the photo, you can see a slow leak from that round thingy in the middle of the photo. This looks to me like the back side of the gear box, behind the starter motor. (I've never had one of these apart, so I'm not sure what I'm looking at). This doesn't look like a simple gasket issue, so I don't know what approach to take. Thanks for any help you can offer! Shawn Link to comment Share on other sites More sharing options...
motoguzznix Posted June 20, 2007 Share Posted June 20, 2007 Shawn This seems to be an inserted steel plug. Dismount the cover, unplug it and reinstall it with a good sealer (green Loctite) after cleaning and ungreasing. Link to comment Share on other sites More sharing options...
Guest ratchethack Posted June 20, 2007 Share Posted June 20, 2007 I just took a gander at my trans. I've got a much slower "seep" at the same place. Not enough to even think about at this point. Now this is just me, but in your case, here's where I'd consider a borderline bodge. I'd do a thorough degreasing of the external area and bodge-on a fillet of sealant at the offending joint. It's a low risk, low effort approach, with no downside. If it doesn't work, you can always get properly invested in the thing and do it up correctly as MGNX suggested. Link to comment Share on other sites More sharing options...
Shawn Stepper Posted June 20, 2007 Author Share Posted June 20, 2007 Thank you both for the excellent advice. I'll take the quickie approach first, and see how that goes. I wouldn't bother if it were a slow leak, but there is a puddle under my bike every time I go to ride! Thanks! Link to comment Share on other sites More sharing options...
richard100t Posted June 20, 2007 Share Posted June 20, 2007 You may want to make sure that you arent overfilling the gearbox with too much fluid. That thing shouldnt just leak out onto your floor when its not running either. Link to comment Share on other sites More sharing options...
Guest ratchethack Posted June 22, 2007 Share Posted June 22, 2007 Just an observation, but I don't b'lieve overfilling is the culprit here. The plug is about 3" above the trans lube level window on the other side. This would indicate that wot's seeping out (I assume it's more of a seep than a leak) is being thrown up on the inside of the box by the gear cluster, gradually making its way past the plug, collecting in the recess on the outside of the plug, then migrating down the outside. Wot appears on the floor is likely coming from wot's accumulated outside the case by the time it's parked. Link to comment Share on other sites More sharing options...
