timing chest laeaks at alternator
Guest ffatdad
My 2002 lemans is leaking oil at the alternator. I have replaced the seal & oring on the spacer but it is still leaking. The previous owner had siliconed the back of the spacer which I found when i dissasembled the bike. any sugestions ? this bike has had the cases repaced on the recall. Builup of presurre in th chest maybe? Appears to leak around the o ring. any sugestions would be appreciated.
THANKS, JIM
Guest Nogbad
If there are no surface finish issues on the seal and "o" ring mating parts, then it would be worth checking that the crankcase breather is clear.
