Guest SoCalDon Posted July 21, 2007 Posted July 21, 2007 Ok Guzzi Mechanics, what’s the trick to pulling this out?
Guest ratchethack Posted July 21, 2007 Posted July 21, 2007 Don, I'd be surprised if your local Auto Parts Mart didn't have a perfectly serviceable version of this: http://buy1.snapon.com/catalog/item.asp?P6...=1644&store -- for around $5.
Guest SoCalDon Posted July 21, 2007 Posted July 21, 2007 Just picked one up. I also got a pick thing. The lever tool won't fit in there. The pick is too thin and weak to pull it out.
jrt Posted July 21, 2007 Posted July 21, 2007 Dental picks are the way to go. They are incredibly strong and resilient. I used to buy them surplus from the dental school at the University...no more. You might find out what UCLA or UCSD or whichever dental school is closest to you does with their used ones.
dlaing Posted July 22, 2007 Posted July 22, 2007 Do you pick from the Inner or Outer Diameter of the seal? I am guessing the outer is too tight, but damaging the shaft would be my fear if working it out with tools digging at the ID.
Guest SoCalDon Posted July 22, 2007 Posted July 22, 2007 Do you pick from the Inner or Outer Diameter of the seal? I am guessing the outer is too tight, but damaging the shaft would be my fear if working it out with tools digging at the ID. I'm thinking I'll do less damage if I take the cover off. Time to find a gasket.
Josh Posted July 22, 2007 Posted July 22, 2007 Your on the right track, take the timing chain cover off.
Guest ratchethack Posted July 22, 2007 Posted July 22, 2007 The lever tool won't fit in there. Hm. Can't imagine why not, unless it's the wrong size for the job. You hook under and feel for "purchase" against solid steel, and as may be necessary, lever against a flat blade screwdriver or something else laid flat across the casting boss with a spacer (washer or what have you), so you aren't levering against the seal itself, and gently coax the seal out, one sector of the circle at a time, working around the diameter, and Robert's y'er Ma's favorite sibling.
rocketeer Posted July 22, 2007 Posted July 22, 2007 [Does anyone have a number for that seal? Mine started to leak and I would like to have the seal there when I take the original out to save time or at least the dimensions. thank you.
pete roper Posted July 22, 2007 Posted July 22, 2007 The late model ones are directional Viton seals and are superior to the earlier flurocarbon type. Another advantage of doing the job by pulling the cover is that it allows you to replace the o-ring inside the sleeve which is quite often the source of the original leak and seal the sprocket end of the sleeve with a smear of silicone. pete
jrt Posted July 23, 2007 Posted July 23, 2007 Do you pick from the Inner or Outer Diameter of the seal? I am guessing the outer is too tight, but damaging the shaft would be my fear if working it out with tools digging at the ID. Inner, but I have been known to get frustrated and just cut a hole in the flat surface and use that to pull. I think one would have to try in order to damage the shaft. Have to agree with previous- it's probably a better idea to go ahead and remove the cover.
rocketeer Posted July 23, 2007 Posted July 23, 2007 Thanks for the tips and information ,I guess I`ll take the cover off.
Guest SoCalDon Posted July 24, 2007 Posted July 24, 2007 Just got back from a MGC Drive by. Mark and Fader gave me the hook up. There is a small O-Ring under the sleave. When I have the cover off the sleave comes off. Then I'll put the new O-Ring on with some "The Right Stuff" If I don't screw it up it should come out great.
