I have today bought a brand new (left over from 2004) Cafe Sport with Öhlins suspension.
Last year I bought a brand new (left over red/gray 2002-3 Le Mans) and I think its a wonderful bike. Just came home from Mandello del Lario, a tour of 3 500 km.
For many years i have loved the V11 but then in 2003 when I bought a motorcycle again after many years without (had a big crash in 2005) I wen`t and bought a Triumph instead!! Luckily I have now managed to buy two new V11, god is really good.
Now to my question, i haven´t driven the Cafe Sport yet and I`m wondering, are there bif difference in how the engine feels? Any other big differences?
I believe the engine is no different, but the sitting position will be much friendlier on the later Sport and the suspension should make a noticable improvement.
We are waiting for you ride reports! :bike::race:
I agree with Docc. The Ohlins suspension is a big improvement and the Cafe's tubular upright bars are (at least for me) much more comfortable than the LeMans clip-ons. The clutch may be different (?), but the engine is the same ol' luvable lump :race:
Enjoy. :rasta:
Enjoy. :rasta:
As you probably already had understand, my crash was in 1985 and not 2005. Anyway, what was realy my question was about the engine. I know the 2004 model has higher compression, catalysator etc...but how does the 2004 engine feels, is it stronger/weaker, in the low/high rpms... are there less vibrations due to the changes, is it qiucker/slower, is it smoother...
Mario
Mario
dynocharts have shown the newer engine to have more mid-range.
I don't recall if the low end also benefits.
The high end was about the same.
I am surprised there really have not been many comparisons made.
Maybe in this thread EDIT Motoguzznix post 52 looks interesting
http://www.v11lemans.com/forums/index.php?...;hl=compression
If I'm reading it right, I think the OP is referring to the difference between an '02 V11 & his new '04. No difference in powerplants beyond the addition of the front x-over [to control the 4-5k rpm hole in the powerband] & the change to the fuel-pump/gas tank/etc. to cure the vapor-lock issues, so the only "power difference" would be resulting from different TPS settings & valve lash settings [ie, initial setup + wear & tear/breakin...]
:mg:
:mg:
They also raised engine compression in the models with the front crossover.
But yah the gains are small and could have simply been a variation of state of tune.
Losing the 4-5k hole is certainly a good thing, but having exhaust leaks and cracks there does not seem to be worth the trade off.
I can't recall if it was Greg or Pete who stated at one point that the "increased compression" was almost certainly pure advertising dept. hyperbole, since none of the relevant part #s had changed in the pre- or post-'03 engines, but I do seem to recall seeing that around here somewhere... :huh2:
I'm in agreement w/ you on the observation that the smoother powerband isn't worth the added failure points in the ex-line, esp. as it seems the real culprit is the dang pre-muffler [much as the predecessors to the V11, the 1100 Spot/Sporti had been plagued by the "colostomy bag" plenum that similarly upset the powerband.]
I'd rather see if the Griso headers can be retrofit to the V11 and get a proper 2->1->2 exhaust than shell out the ducats for RacerX's lovely replacments for the stock units, but that's just me. Fortunately, I haven't the need to do any of that yet, which is a lucky thing since I'm broke... ;)
:mg:
:mg:
That may be true about the compression????? There is a change in piston/cylinder part numbers but I think it is occured much earlier, as the change appears in the pre-2002 parts catalog :huh2: 2003 was a transition year and part numbers might not have made it to the 2003 parts catalog where there is no sign of higher compression or enhanced oil cooling/lubing. I have not found a 2004 parts catalog.
Not sure what you mean about the Griso headers. They are two into one, not two into one into two, right?
Yes, the stock Griso headers mated w/ the g#dawful ash-can exhaust is 2->1; Griso headers mated to a V11 w/ a suitably ingenious collector would retain the stock classic good looks of the dual exhaust, & so be 2-1-2... Think of Enzo's "Cobra" exhaust, only w/ auditory acceptability and using a preponderance of factory parts [always a good thing when trying to sneak it past the ever-zealous gendarmerie...]
:thumbsup:
:luigi:
:bike:
