DeBenGuzzi Posted August 25, 2007 Posted August 25, 2007 alright I've had the tank off like 8 times in the last 2 weeks and I can't get the regulator to f'n stop leaking, I replaced the oring that didn't work, I added some gas proof gasket sealant and let it sit for 24 hrs now I gotta clean that out as it didn't help at all. I don't understand I cleaned inside the regulator and replaced the ring with an identical gas specific oring its not coming from the spout its coming from around the c-clip which means the lower oring is leaking and I'm about at my wits end here, I'm gonna hurl the damn bike off a cliff here shortly. I should just remove the damn thing and cap it somehow, not sure how but I can't take it anymore ANY help would be great, I wanted to ride it to the "wheels of Italy" show on sunday but I can't obviously take it anywhere leaking petrol. ARRRRRGGGGHHHHHHHHHHHH
jrt Posted August 25, 2007 Posted August 25, 2007 take a close look at the mating surfaces. If they're clean and flat, then that's not the problem. Could there be a small crack? What do you mean by regulator? There's a pressure regulator on the r/h side- is that what you mean? Where is it leaking from- the outlet of that pressure regulator or the seal at the tank? Gas tends to follow crevices, so where you see it might not be the source. A piece of toilet paper is sufficiently absorbent that you can follow a fluid leak.
DeBenGuzzi Posted August 25, 2007 Author Posted August 25, 2007 thanks for the sage advice, that is possible it always leaks on the inside of the regulator but that could just be the angle of the bike/tank for that, its on the rh side if youre sitting on the bike, has the spout thats not a spout and leaks around the C clip, I'll take it apart (again) tomorrow and look for scrapes crackes and gouges to make sure that isn't the problem, I bet I'll have a dickens of a time finding a replacement for that stupid thing if it is broke,
