dp.guzzi Posted September 8, 2007 Posted September 8, 2007 Hello All I have a 2002 LeMans, purchased new in May 2005. It came with Bridgestone tires. I now have 8000 miles and need new tires. Q1: How many miles should I expect from a set of tires ( I guess about 8000 miles) Q2: What tires do you guys recommend? Thanks
waspp Posted September 8, 2007 Posted September 8, 2007 Welcome dp guzzi! To be honest I haven't cheked my tire mileage exactly, usually the front lasts longer than the rear but 8000 seems about right. I am on my second set of Michelin pilot roads which I like very much, good grip and wear well.They also have a new tire coming out soon a dual compound tire already available in Europe which is supposed to be very good, harder compound in the center for waer and softer on the edges for grip. Hal
Todd davis Posted September 9, 2007 Posted September 9, 2007 Hello All I have a 2002 LeMans, purchased new in May 2005. It came with Bridgestone tires. I now have 8000 miles and need new tires. Q1: How many miles should I expect from a set of tires ( I guess about 8000 miles) Q2: What tires do you guys recommend? Thanks I to have an 02 LeMans. I'm currently running Metzler Z6's. Quite a bit better than the Bridgestones that came on the bike, especially after 5 years worth of aging.
quazi-moto Posted September 9, 2007 Posted September 9, 2007 My original Bridgestones were kinda lousy. The front got all cupped and the bike steered and handled like a cow on ice. Well, maybe not that bad, but its much better with the Pirelli Diablos.
Skeeve Posted September 9, 2007 Posted September 9, 2007 Hello All I have a 2002 LeMans, purchased new in May 2005. It came with Bridgestone tires. I now have 8000 miles and need new tires. Q1: How many miles should I expect from a set of tires ( I guess about 8000 miles) Q2: What tires do you guys recommend? Thanks Pirelli Dragon Strada/Metzler MEZ6 [same tire, different brands]; use a 170/60 profile rear tire instead of the stock 180/55 to sharpen up the handling. I haven't actually got around to trying this on my own, still running the Bridgestone's ['cause I'm cheap!], but it seems to be the general consensus when this topic has arisen in the past (which about every 6 months or so?)
O2 V11 Posted September 9, 2007 Posted September 9, 2007 dp, I have 8300 miles on my bike and am on my third rear and second front. The original hopeless Bridgestone rear was worn out at 4500 miles. The front badly cupped as have many others. I replaced both with Continental Contiforces, a 170/60 rear and a 120/70 front. Going down a size on the rear as many have found is worthwhile. These tyres are a marked improvement over the original fitments. This rear was worn out after 3000 miles. I don't like mixing brands so this was replaced with another Continental, this time the standard 180/55. The front has lasted well, this will changed when the current rear tyre wears out. The front is an interesting dual compound, softer on the sides and harder in the centre, you can see the higher wear rate on the sides. I guess our roads being of the coarse chip type are a lot harder on tyres than roads in other parts of the world. My aggressive riding style as well isn't conducive to long tyre life. There is a lot written here about peoples tyre preferences, just do a search on the subject. Don't forget to grease your drive shaft while you have your rear wheel off. Rob
BrianG Posted September 9, 2007 Posted September 9, 2007 Pirelli Dragon Strada/Metzler MEZ6 [same tire, different brands]; use a 170/60 profile rear tire instead of the stock 180/55 to sharpen up the handling. I haven't actually got around to trying this on my own, still running the Bridgestone's ['cause I'm cheap!], but it seems to be the general consensus when this topic has arisen in the past (which about every 6 months or so?) If you mean Pirelli Diablo Strada I agree 100%. And I like them better than the Metzler of apparent same lineage. I found the Pirelli more progressive in slippage. YMMV
antonio carroccio Posted September 9, 2007 Posted September 9, 2007 If you mean Pirelli Diablo Strada I agree 100%. And I like them better than the Metzler of apparent same lineage. I found the Pirelli more progressive in slippage. YMMV It's always the same story: the egg or the chicken? Perhaps we have something in common, Pirelli or Metzeler is always the right choice.
Baldini Posted September 9, 2007 Posted September 9, 2007 To say any tyres are always the right choice is nonsense. Tyre preference is always subjective & it seems to me most opinion is based on very limited experience of the options available. Most modern radials from major brands seem good. Choice depends on handling & grip preferences, availability, cost & wear. Tyres that grip better wear faster. Wear on any tyre depends entirely on how you use it but can vary from maybe 1k miles for a hard ridden sport tyre to 10k + for a very steady rider on a touring tyre. Performance of some tyres goes off as they wear, others perform fairly consistently. How do you use the bike? KB
Guest motomentel Posted September 9, 2007 Posted September 9, 2007 Hello All I have a 2002 LeMans, purchased new in May 2005. It came with Bridgestone tires. I now have 8000 miles and need new tires. Q1: How many miles should I expect from a set of tires ( I guess about 8000 miles) Q2: What tires do you guys recommend? Thanks I also have a 2002 Leman's 14890 for milage . I just replace oe tires with Michelin Pilot road stock size's I went with the Michelins based on my stile of driving ( not to agessive ) I'm more concern about traction if caught in the rain. I really like the new tire's
Skeeve Posted September 10, 2007 Posted September 10, 2007 If you mean Pirelli Diablo Strada I agree 100%. And I like them better than the Metzler of apparent same lineage. I found the Pirelli more progressive in slippage. YMMV Yes! "Diablo," not "Dragon" Stradas. Sorry 'bout the confusion there...
Guest ch-zep Posted September 10, 2007 Posted September 10, 2007 giuseppe.foppa@rtsi.ch Hello All I have a 2002 LeMans, purchased new in May 2005. It came with Bridgestone tires. I now have 8000 miles and need new tires. Q1: How many miles should I expect from a set of tires ( I guess about 8000 miles) Q2: What tires do you guys recommend? Thanks giuseppe.foppa@rtsi.chTry the the new bridgestone bt 021! i'm very happy with it. Hello All I have a 2002 LeMans, purchased new in May 2005. It came with Bridgestone tires. I now have 8000 miles and need new tires. Q1: How many miles should I expect from a set of tires ( I guess about 8000 miles) Q2: What tires do you guys recommend? Thanks
ptrkbeam Posted September 11, 2007 Posted September 11, 2007 Welcome! Excellent taste, that Champagne '02. Previous owner had Conti Road Attacks mounted at 7210 miles. I believe these replaced whatever the originals were. Bought the bike at about 10,500 miles and had the Contis replaced with Metzeler Z6 Roadtecs at 14766 miles. Rear was sort of squared off from mostly straight-line commuting, but the tread was lower than I like riding on anyway, especially in the rain. Front had maybe 1000 more miles left but didn't want to mix. New tires are nice.
Ryland3210 Posted September 11, 2007 Posted September 11, 2007 I wondered, what is the best tread design for rain? I'm not asking about rubber composition, just the tread. I had a detailed discussion with some technical types at the NY motorcycle show. My question was, given the few grooves and wide spacing compared to automobile tires intended for good traction on wet roads, how effective were the grooves on the typical sport bike tires at preventing hydro planing? I'm sorry to say that none of those I asked at the show could give me a satisfactory answer. When I pressed on the issue, the general answer was that the tire design had primarily revolved around dry pavement cornering and traction. If I'm riding long distance and get stuck in the rain, I feel somewhat nervous about hydroplaning, and find myself being very conservative around corners. (Maybe it has something to do with the screw put in my knee and three operations to hold it together when I slid off the road a long time ago). The tread design on my Yamaha Venture heavy cruiser is much more like a traditional universal tire, and I feel more secure. I'm willing to sacrifice some dry corning traction if I can get reasonable life and the best wet cornering traction. I'm looking for suggestions. Thanks in advance, John
Dan M Posted September 11, 2007 Posted September 11, 2007 Hello All I have a 2002 LeMans, purchased new in May 2005. It came with Bridgestone tires. I now have 8000 miles and need new tires. Q1: How many miles should I expect from a set of tires ( I guess about 8000 miles) Q2: What tires do you guys recommend? Thanks Most modern sport touring tires will give a nice balance of traction and wear and be considerably better than the factory Bridgestones. I replaced the Bridgestones on mine with Pirelli Stradas and really like them. I have expereince with the Metzeler Z6 on another bike and they are really nice as well.
