savagehenry Posted September 18, 2007 Posted September 18, 2007 Anyone aware of a "Front and Rear wheel mounting procedures/ tips" thread, I've searched to no avail. Plenty on removal, but not much in the way of mounting. My owners manual feels a bit short on detail and is short on CLEAR pics. I would just like to double check this important area of maintenence. Doing tires, want bearings loaded properly, S.H.
jrt Posted September 18, 2007 Posted September 18, 2007 The front should be pretty straight-forward. For the rear, I always suggest that the bike be propped up high- higher than you think- to facilitate removal and replacement. If you are talking about side-loading the bearing, it's not real critical (or I've been weirdly lucky). Just get the axle moderately tight, then cinch up the safety bolts. For packing (non-sealed) bearings, I use a needle that I JB-welded into a grease nipple. I put the needle into the back of the bearing and put in a squirt of grease, move it two or three balls or cylinders and do it again until I make it all the way round the bearing. It's a mess.
