kalev11 Posted September 23, 2007 Posted September 23, 2007 I have some issue with my gearbox and I cant quite put my finger on it. I seem to feel backlash when shifting and sometimes my shift lever will hang up untill I begin to release the clutch then it will pop back down. Other times when I release the clutch it will grind as if in false nuetral then clunk into gear. I think about clutch, cush, shifter adjustment? Any ideas ? The bike is a 01 V11 Sport. Thanks
Paul Minnaert Posted September 23, 2007 Posted September 23, 2007 just look carefull when moving the shifter, it can be a bolt came lose, or can't move freely because there is something on it's way.
pete roper Posted September 23, 2007 Posted September 23, 2007 2001? Is it eligible for the gearbox recall? If so, has it been done?. Otherwise, try playing with the pawl adjuster and seeing if the problem goes away. Pete
kalev11 Posted September 23, 2007 Author Posted September 23, 2007 2001? Is it eligible for the gearbox recall? If so, has it been done?. Otherwise, try playing with the pawl adjuster and seeing if the problem goes away. Pete Yes it did have the recall work done on the gearbox I hope they did a good job. I have seen some other posts on problems such as mine and I will look into the eye of the acorn nut for any improvment it may have to offer.Thanks Have the six speed trannys been going thru any problems such as dog rounding or other failure of the gears or problems with gauling of shafts, bushings or other internal parts? Thanks again think its time to go ffor a ride.
