Guest frankdugo
The Triumph Tiger Indicator assembly is £26.34+Vat :o
A Buell parts supplier in the UK emailed the following...
your part number y0039.k is correct for the outer lense only, it retails at
£2.88.
the part number y0503.02a8 is correct for the whole indicator assembly, this
retails at £15.54.
the inner amber coloured lense is not available separately.
Can someone in the US find the P/N for the amber insert ?
Guest frankdugo
harley/buell-turn signal,left y0526.k turn signal right y0527.k the inserts are orange. am guessing they cost around $15 us
I bought them a few months ago from a Harley Dealer for about $11 each, and I've heard of cheaper prices. I like the flex mount. The mounting holes had to be drilled out a bit, are still small enough for the MG parts if one ever wants to go back to original.
  • 2 weeks later...
£2.88.
retails at £15.54.
Found some indicators http://shop.wemoto.com/pictures.dyn?u=5836261qqq3657982
£11.75 each
They have a flexable stem and just require the mounting hole to be increased in size and moved back slightly ( a round file did it in no time)
The only problem is that they don't come with nuts, its a fine metric thread (1.25 I think) my local nut and bolt supplier couldn't help :huh2: but my mate at a S*z*k* dealer found me some straight away.
Guest frankdugo
looks good!smoke,s nicer too.
