RonV11 Posted November 10, 2007 Share Posted November 10, 2007 I just started noticing a clunk that is not related the engine RPM. (The clunk does not increase with RPM, nor does it drop when I pull in the clutch.) It's slight, and not very noticeable. Starts at about 30 MPH. Its kinda like when a rock is stuck in your tire tread. I haven't spent much time diagnosing it... Just wondering if someone here has run across this already. Thanks Ron Link to comment Share on other sites More sharing options...
pete roper Posted November 10, 2007 Share Posted November 10, 2007 Re the trunnions aligned properly on your drive shaft? Pete Link to comment Share on other sites More sharing options...
RonV11 Posted November 10, 2007 Author Share Posted November 10, 2007 Thanks Pete. I'm almost afraid to ask... Whats a trunnion? And do they need periodic adjustment? Hers's some additional info I forgot to include... I feel it only in the foot pegs and more on the left peg. Ron 2001 V11s Link to comment Share on other sites More sharing options...
dlaing Posted November 10, 2007 Share Posted November 10, 2007 What is the tempo? about four beats per second? Or is it irregular? What happens as speed increases? If it were the shaft the frequency would increase as speed increases, or it would go away before you notice a change in frequency. Does it matter what gear you are in? Link to comment Share on other sites More sharing options...
RonV11 Posted November 10, 2007 Author Share Posted November 10, 2007 I knew I'd forget something... Thanks for helping me focus on the details... It is regular and increases/decreases with speed (up/down). It's not very noticeable and with the engine running it's very difficult to notice as engine vibration masks the clunk. I notice it more while coasting with the clutch lever pulled in. Good question about gear selection. I'll check that out as I would assume that it would point to a transmission problem. Thanks Ron Link to comment Share on other sites More sharing options...
Guest ratchethack Posted November 10, 2007 Share Posted November 10, 2007 Whats a trunnion? And do they need periodic adjustment? See discussion and illustration in this thread: http://www.v11lemans.com/forums/index.php?...mp;#entry104913 Link to comment Share on other sites More sharing options...
docc Posted November 10, 2007 Share Posted November 10, 2007 Not that this would actually create a noise like that, but it is worth checking the shock's eye bolt to the swing arm to be sure it is complete (not a half eye) and not cracked. Link to comment Share on other sites More sharing options...
Guzzi2Go Posted November 12, 2007 Share Posted November 12, 2007 ...It is regular and increases/decreases with speed (up/down). It's not very noticeable and with the engine running it's very difficult to notice as engine vibration masks the clunk. I notice it more while coasting with the clutch lever pulled in. Good question about gear selection. I'll check that out as I would assume that it would point to a transmission problem. ... This describes pretty much the noise my broken rear wheel bearings generated. The old bearings took the noise with them as they were replaced. Pushing the bike around for a couple of meters (20-30?) in neutral and with the engine switched off may give you a better idea where does the noise come from. I bet on bearings. Link to comment Share on other sites More sharing options...
Martin Barrett Posted November 12, 2007 Share Posted November 12, 2007 Put me down also for the rear wheel bearings, a clunk at low speed was the first indicator I had that mine had gone. Link to comment Share on other sites More sharing options...
RonV11 Posted July 26, 2008 Author Share Posted July 26, 2008 It's taken me a while to get back to the V11... And a BIG thank you to the people that provided input. I just wanted to let you all know what was causing the "clunk". The envelope please... AND the winner is... Wheel Bearings! Congrats to Martin Barrett & Guzzi2Go. You guys nailed it. The Left side had a radial crack. I'd never seen that before. Thanks again. Link to comment Share on other sites More sharing options...
