Guest Nickos Posted August 27, 2003 Posted August 27, 2003 I see five relays under the seat of the Lemans, three larger and two smaller. Do we put the same Bosch relay in place of all those five? I assume it is the same Bosch (0 332 207 307) that I use in my Centauro already. Thanks Nickos
dlaing Posted August 27, 2003 Posted August 27, 2003 The Bosch number you have is definitely right for 2000 and 2001 model years. What year is your bike? Did you buy it new?
Guest Nickos Posted August 27, 2003 Posted August 27, 2003 It is a 2001 model, bought it new (my cousin actually but we share bikes) and I wanted to know if the same Bosch relay could be placed in all five slots. Many wishes O ====== = = = = = // > ===== ==== === = = = = [+] < [+] ====== ==== == = = = = = Nickos Costopoulos - Athens, Greece 1986 K100RS - 1996 Centauro V10 (Auntie and Eva) http://flyingbrick.freeyellow.com
gthyni Posted August 27, 2003 Posted August 27, 2003 Short answer: yes Not that I have had any problems but it has been pointed out that the original Siemens relays was a common point of failure. So I though "better be safe than sorry" and replaced them all.
dlaing Posted August 27, 2003 Posted August 27, 2003 Yep you can use that Bosch number for all. Long answer.... The only odd relay requirement is for the headlight relay which is designed to dim when the starter relay is activated. But you do not have to worry because all the Bosch relays of that number will work for the headlight relay, as well as the others. The headlight relay uses one more terminal than the other relay sockets. That terminal simply goes unused when the relay is used in the other sockets.
al_roethlisberger Posted August 27, 2003 Posted August 27, 2003 ....my 2002 came with the "large/tall" and "small/short" Siemens relays mixed&matched from the factory as well. I was told by many that the "large/tall" units were the new and improved Siemens and that it seemed like they were reliable replacements. I still swapped them out to the Bosch, and in regard to relays, it's been trouble-free so far. I keep the original "large/tall/new-model" relays in my tool bag for spares. al
Guest Nickos Posted August 28, 2003 Posted August 28, 2003 Thank you all guys. I appreciate your time to answer. Happy riding. Nick
Dirtybill Posted August 28, 2003 Posted August 28, 2003 ....my 2002 came with the "large/tall" and "small/short" Siemens relays mixed&matched from the factory as well. I was told by many that the "large/tall" units were the new and improved Siemens and that it seemed like they were reliable replacements. I still swapped them out to the Bosch, and in regard to relays, it's been trouble-free so far. I keep the original "large/tall/new-model" relays in my tool bag for spares. al My relays were replaced with "The New Improved!!" Siemens relays and so far so good.
