joe camarda Posted November 29, 2007 Posted November 29, 2007 Does anyone know if a Ducati Monster front wheel will fit a 04 Ballabio/Coppa?
Guzzirider Posted November 29, 2007 Posted November 29, 2007 There are many versions of the Monster front wheel- not heard of anyone doing the swap- doesnt mean its not possible. If you mean the very lightweight Marchesinis as fitted to my S4Rs I could check in the garage for you to see if it looks feasible if you had the right spacers etc. would look weird unless you had a smiliar rear though. Guy
Paul Minnaert Posted November 29, 2007 Posted November 29, 2007 Things to check, the distance between brake disk mounting, that might be narrower with the ducati. But narrower is easier solved than wider. Most duc do have a 25mm spindle, only the lighter ones maybe not, so then you need to change bearings/spacers. Spacers can always made fit.
