Guest BIGGERJIM Posted December 19, 2007 Share Posted December 19, 2007 hey yall i am a little confused what size is the forks on front of 2001 v11 sport going to buy springs and could not find a difinative answer. do yall recommend sonic, hyper pro, progressive, or other i am 300lbs soaking wet and i need some good ones 41mm or 43mm thanks in advance bigger jim Link to comment Share on other sites More sharing options...
Tom M Posted December 19, 2007 Share Posted December 19, 2007 You have 40mm forks Jim. I don't know if the HyperPro progressive spring will be adequate for your weight since most people here who have them and are happy with them are at least 100 lbs lighter than you, so you may need straight-rate springs. I had good luck with Traction Dynamics springs but I'd try Sonic if I was buying today. Here's a link to their spring rate calculator: http://www.sonicsprings.com/catalog/calcul...35a46880b121ae7 Once you go with firmer fork springs you'll probably find that you need to go to a stiffer rear shock spring too. FWIW I have 1.05kg/mm up front and a 1.0 rear spring, I think a 1.05 kg/mm rear spring would balance the suspension better. Link to comment Share on other sites More sharing options...
Guest BIGGERJIM Posted December 19, 2007 Share Posted December 19, 2007 You have 40mm forks Jim. I don't know if the HyperPro progressive spring will be adequate for your weight since most people here who have them and are happy with them are at least 100 lbs lighter than you, so you may need straight-rate springs. I had good luck with Traction Dynamics springs but I'd try Sonic if I was buying today. Here's a link to a spring rate calculator: http://www.sonicsprings.com/catalog/calcul...35a46880b121ae7 Once you go with firmer fork springs you'll probably find that you need to go to a stiffer rear shock spring too. FWIW I have 1.05kg/mm up front and a 1.0 rear spring, I think a 1.05 kg/mm spring would balance the suspension better. thanks tom i will look them up Link to comment Share on other sites More sharing options...
dlaing Posted December 21, 2007 Share Posted December 21, 2007 Once you go with firmer fork springs you'll probably find that you need to go to a stiffer rear shock spring too. FWIW I have 1.05kg/mm up front and a 1.0 rear spring, I think a 1.05 kg/mm rear spring would balance the suspension better. Good recommendations. I think you mean 10.5kg/mm rear. Just to throw in my nit-picking two cents, if I weighed 300lbs, I might shoot for just a little more, like maybe 1.10kg/mm front and 11kg/mm rear (about 600or 625lb/inch rear). In any case you will do much better than stock if you increase the spring rate above stock. Link to comment Share on other sites More sharing options...
Tom M Posted December 21, 2007 Share Posted December 21, 2007 Good recommendations.I think you mean 10.5kg/mm rear. Just to throw in my nit-picking two cents, if I weighed 300lbs, I might shoot for just a little more, like maybe 1.10kg/mm front and 11kg/mm rear (about 600or 625lb/inch rear). In any case you will do much better than stock if you increase the spring rate above stock. You're right on the rear spring Dave, my bad! Link to comment Share on other sites More sharing options...
