il_cacciatore Posted February 2, 2008 Share Posted February 2, 2008 Hi, really want a V11 and went to see one today. I was looking at the frame and noticed that compared with the Factory images the frame below the fork seems shorter. I've highlighted in this photo what I mean. Wondering if some bikes came like that from the factory? Also, do the rocker covers 'flake'? Cause he seems to have touched them up. Its a 2001 v11. Everything seems to check out ok, he's had the relays replaced and ecu replaced. Done an HPI check and it hasnt been registered crashed or anything. Any info is appreciated. Cheers Link to comment Share on other sites More sharing options...
Philmac Posted February 2, 2008 Share Posted February 2, 2008 The frame mounting points are quite high up on the timing casing - should be the same on all V11 models. I'm afraid the paint does come off particularly where hit be insects/road debris etc. I've already had my rocker covers resprayed once (doesn't effect performance though ). Phil Link to comment Share on other sites More sharing options...
il_cacciatore Posted February 2, 2008 Author Share Posted February 2, 2008 Thanks phil! I'm confident its a good purchase. I'm the sort of person that looks for problems even if there aren't any! Cheers. Link to comment Share on other sites More sharing options...
Ballabio Bertie Posted February 2, 2008 Share Posted February 2, 2008 Hey,what's a bit of flaky paint here and there? Ride it,service it,get it dirty,clean it up......repeat as often as possible,just enjoy it!! I see you're in Scotland,will you you be coming to Ken Bridge in May? (Oh,and welcome aboard by the way...) Link to comment Share on other sites More sharing options...
Skeeve Posted February 2, 2008 Share Posted February 2, 2008 Hi, really want a V11 and went to see one today. I was looking at the frame and noticed that compared with the Factory images the frame below the fork seems shorter. I've highlighted in this photo what I mean. Wondering if some bikes came like that from the factory? The actual frame (spine) was lengthened in '02? [w/ introduction of v11 LeMans, iirc]; that might be the source of your perception that the engine mount is different. FWIW, everyone here w/ the older, "short frame" has no complaint about the handling: Guzzi apparently made the change to solve a non-problem fabricated by the moto-press to give themselves something to write about... Link to comment Share on other sites More sharing options...
Guest ratchethack Posted February 2, 2008 Share Posted February 2, 2008 Hi, really want a V11 and went to see one today. Any info is appreciated. il Cacciatore, as mentioned by Skeeve above, the "short frame" V11's Sports and one other model (can't recall for absolute certain, but I b'lieve it was the Rosso Mandello) were produced in 2000 and (as I recall) also in part of '01. The differences in geometry amount to a change in fork rake of one degree from that of all other V11 variants, the '00 Sports and RMs being 25 degrees, and all other LM and Sport variants being 26 degrees. I've carefully measured mine against the wheelbase of a '04 LM and the difference amounts to 5/8" (16 mm), measured spindle to spindle. There's next to ZERO possibility that anyone would be capable of seeing this difference "by eye" or on a photo. The bolt-on front subframes (the part visible below the steering head circled in your photo) are identical across all V-11 models, so I b'lieve you may've been imagining things, or looking at a photo that incorrectly reflects a perceived difference due to camera angle, parallax, or some other cause of an optical illusion. There are persistent "old wives' tales" about "a problem" with the geometry and handling of the "short frame" V11's. Again as Skeeve noted, there's never been any legitimate basis in fact on this, (nor any credibly documented examples of it) as has been discussed (and refuted) repeatedly and at length on this Forum. Many of those who fully appreciate the handling of the different V11 models and have ridden both for comparison (count me in) prefer the sharper handling of the "short frame" Guzzi's, and many "in the know" seek them out for this reason. I b'lieve none other than the Oracle of Bungendore hisself has commented that he favors the "short frame" bikes. Have fun with your selection and welcome to the nuthouse. As a newcomer, I would urge you to take little notice of any lingering fallout from the recent Forum brouhaha that may seem somewhat "odd". Some o' us have been known to get as loopy as a banana boat in a swimming pool this time o' year. Link to comment Share on other sites More sharing options...
Lamedog Posted February 2, 2008 Share Posted February 2, 2008 I'm the sort of person that looks for problems even if there aren't any! Mr. Cacciatore, you have truly found a home here. Fixing things before they become a problem, I might say even in their earliest stages of hypotheticalness, is a lifestyle choice amongst some of us (particularly those not dependent upon the bike for primary transportation). Its a beautiful bike, have fun and welcome to the fold. I may advise picking up both the shop manual as well as a copy of "Guzziology". And the search feature here is a great help. Welcome. Link to comment Share on other sites More sharing options...
Guest sonic Posted February 2, 2008 Share Posted February 2, 2008 Hey,what's a bit of flaky paint here and there? Ride it,service it,get it dirty,clean it up......repeat as often as possible,just enjoy it!! I see you're in Scotland,will you you be coming to Ken Bridge in May? (Oh,and welcome aboard by the way...) couldnt put it better myself BB my 04 v11sport has a bit of flacky paint around the edges but are getting that sorted so just stick to the above quote and do what i think most guzzi riders do!! Link to comment Share on other sites More sharing options...
Guest frankdugo Posted February 2, 2008 Share Posted February 2, 2008 agreement to all of the above.those first two years had a trans gear recall;which should have been done-check.when you ride it you will love it. Link to comment Share on other sites More sharing options...
il_cacciatore Posted February 3, 2008 Author Share Posted February 3, 2008 Thanks for all the comments. I'm well chuffed with my purchase. I was imagining the difference in frame.. Its the same as any other v11. Might make my way upto Orkney for that. Cheers Link to comment Share on other sites More sharing options...
Ballabio Bertie Posted February 3, 2008 Share Posted February 3, 2008 The Ken Bridge rally is in New Galloway, if you come up here you'll miss it... Look up the UK v11 rally thread in Meetings,Clubs and Events. Hope to see you there! Link to comment Share on other sites More sharing options...
il_cacciatore Posted February 6, 2008 Author Share Posted February 6, 2008 Oops got confuddled. Here is a picture of my purchase. Standard except for the raised bars and light fairing. If anyone has a oem top yoke and clip-ons they don't need give me a pm. One thing that strikes me about the design, surely the rubber tank protector gives an ideal place for water to sit? Also, the front engine mounts are rusting a bit and wondered what colour of red would be a near enough match? Link to comment Share on other sites More sharing options...
Ballabio Bertie Posted February 6, 2008 Share Posted February 6, 2008 Nice one!! Enjoy it! Link to comment Share on other sites More sharing options...
Baldini Posted February 7, 2008 Share Posted February 7, 2008 ... The bolt-on front subframes (the part visible below the steering head circled in your photo) are identical across all V-11 models... Later V11's (01/02 onward) do have a slightly different subframe to the original V11. Rear tubes join front near lower mount point. KB Link to comment Share on other sites More sharing options...
il_cacciatore Posted February 7, 2008 Author Share Posted February 7, 2008 About this trans gear recall, how can I tell if its been recalled already? Link to comment Share on other sites More sharing options...
