Guest fifi93 Posted February 4, 2008 Share Posted February 4, 2008 Hello, I have to redo the clutch of my V11 lemans, also I would wanted to know, to plan my day, how long time is it necessary to change two disks and the walnut of the clutch? It is simple or difficult, it is my first essay . thanks Link to comment Share on other sites More sharing options...
Paul Minnaert Posted February 4, 2008 Share Posted February 4, 2008 if it's not the first time then 4 hours or less are possible, but if you are new in this take 8 hours as guide Link to comment Share on other sites More sharing options...
Guest ratchethack Posted February 4, 2008 Share Posted February 4, 2008 Hello, I have to redo the clutch of my V11 lemans, also I would wanted to know, to plan my day, how long time is it necessary to change two disks and the walnut of the clutch? It is simple or difficult, it is my first essay . thanks FWIW, I had my trans out on a Friday, took it in for dealer recall work next day, had it back in same day and was riding on Sunday. I have a well-equipped home shop and wouldn't have been able to do this without. See many posts on "crabbing the frame". Simple vs. difficult is a subjective thing, with lots o' "it depends" attached. . . I found it very straightforward, and took extra time to clean, lube, and adjust everything carefully as it went back together, but that's just me. Good luck. Link to comment Share on other sites More sharing options...
Guest fifi93 Posted February 4, 2008 Share Posted February 4, 2008 FWIW, I had my trans off on a Friday, took it in for dealer recall work next day, had it back in same day and was riding on Sunday. I have a well-equipped home shop and wouldn't have been able to do this without. See many posts on "crabbing the frame". Simple vs. difficult is a subjective thing, with lots o' "it depends" attached. . . I found it very straightforward, and took extra time to clean, lube, and adjust everything carefully as it went back together, but that's just me. Good luck. Thanks for the replies, a friend thought he needed twenty hours to go up the clutch, change electronic box (ECU) then make electronic adjustments.For my part plan 20 hours for all of these tasks seems a bit long, but my friend works slowly. In short!Why not And according to my garage ECUs of V11 lemans 2004, are not adjustable ... is this true? Link to comment Share on other sites More sharing options...
Paul Minnaert Posted February 4, 2008 Share Posted February 4, 2008 what is the ecu change for? They can be programmed, If you have the right equipment. Ecu change on itself is done in 10 minutes, if the bolts don't give a problem. Link to comment Share on other sites More sharing options...
