frt spring set up for fat guys
Guest BIGGERJIM
Like i said in an earlier post i put springs fork seals and fresh oil
in my 2001 v11 sport.
i just thought i would tell the other big boys what worked for me.
1-i got the 1.1 springs
2.7 wt fluid from honda
3-110mm air gap maybe 100mm my measuring stick was not very accurate
4. i cut the spacers the same length as stock minus the differance in stock and 1.1 springs
i am 6 ft and 301lbs and this worked great for me.
i did take it apart three times and change the spacers last time was the charm.
it really wasn't that tough of a job
thanks to the information from you fellas.......
Do you have plans for the rear shock?
I would guess you would need at least a 600#/in spring, Maybe a 650#/in.
Guest BIGGERJIM
hey dlaing
i sure do, it needs something,, mighty stiff
will try to adjust, but, i don't have much faith that's going to do it.
when the wife cools down from the ev11.
it has to have a new ecu, she is still smarting from that lol lol
i had good luck with sonic springs i will probably call on them agian.
thanks bigger jim
