Rob Posted February 18, 2008 Posted February 18, 2008 Hi all-- Still searching for a riser solution for my V11. As there are more solutions for Ducati with 53mm forks, I'm wondering if anyone has tried that on their Guzzi with 54mm forks? Seems like 1mm could be accounted for in adjustment. But am I missing something here? Thanks...
Paul Minnaert Posted February 19, 2008 Posted February 19, 2008 no I don't think 53 will work, the diameter may be one mm off, the circumference is much more.
joe camarda Posted February 19, 2008 Posted February 19, 2008 I used a set of Cycle Cat 53mm risers on my 01 V11 Sport and had them enlarged to 54 mm. Only a reduction of .5 mm in thickness which I didnt worry about. Not to say that the Ducati risers would necessarily work (they may). The Cycle Cats worked because the other dimensions were okay.
