now im in love with the guz again im in the process of fitting bar end mirrors ,ive turned down the bar ends so the mirrors will clamp to those,the trouble is the bar ends are turning around 360 degrees,the counter weight bar is just turning around inside the clip ons.everything is there as it should be,ive checked the manual,,,is the counter weight bar supposed to be glued back inside the handle bar,or should the rubber tubing around the c/b bar expand when the end nut is tightened and hold tight against the inside of the handlebar,,,cheers
ps the other side is ok the counter bar is stuck fast
Yeah, I had the same problem, my solution was to put a thick washer under the pin that goes through the inner shaft. That puts a little more tension on the rubber. They still rotate by hand, but not by riding up to 100mph. (I'm told, LOL) Joe
