Fuel Lines-Disconnect
Guest northend
Hey Guys.
How do you disconnect the fuel lines on an 03 Le Mans?
I cant figure out the damn quick disconnects!!! :angry:
Northend,
It is so easy it is scary! Push the hose towards the fuel take unit, while pressure is held on the hose push the white collar on the hose outward (toward the hose)and the hose will slip off. You will not feel any movement of the white collar so just let the hose slide off. Watch out for fuel, it could be under pressure, some rags around the fitting might be helpful as well as safty glasses just incase the fuel sprays. Oh yeah, I would do this on a cold engine. :thumbsup:
Mike
Guest northend
Thanks for the reply Mike. I Knew I saw it under the Tech. topics. But I couldn't find it and I haven't had too much patience lately, I'm trying to quit smoking! :rasta:
Thanks Again.........Jeff(Northend)
