Wayne Orwig Posted June 4, 2008 Share Posted June 4, 2008 Not necessarily. It might mean the most, or best, oil. Or the cleanest fins. Or the one with the best airflow over the drive box. Too many variables and, sadly, too small a sample to draw any reasonable conclusions. My EV had the highest temp. I am running Mobil 1 with a bit of moly added. Not saying it is or isn't the lube, but in my case, I have the EV rear end 'sealed' a bit by all of the luggage, much more then anything else there. And the CARC units should have more area exposed to cool air. Maybe. The true test would be do do a certain ride, measure it, change the oil, then repeat the same conditions. I must admit that I was surprised to see Docc in the parking lot using that rectal thermometer on everyone's rear and not even cleaning it from rearend to rearend. Sounds unhygienic to me. Link to comment Share on other sites More sharing options...
docc Posted June 4, 2008 Author Share Posted June 4, 2008 Hey, you kept getting back in line! Link to comment Share on other sites More sharing options...
mike wilson Posted June 5, 2008 Share Posted June 5, 2008 The true test would be do do a certain ride, measure it, change the oil, then repeat the same conditions. Better would be a dyno run in an enclosed room. Link to comment Share on other sites More sharing options...
