DougInMA Posted April 10, 2008 Posted April 10, 2008 I believe my fuel pressure regulator is in need of replacement. MG wants to sell me one for about 250 USD which seems a little pricey... this does include the aluminum adapter that attaches to the tank, but I really just need the regulator. The regulator is a Weber RPM 40. Does anyone know where I could find the Weber part or some other replacement? Thanks, Doug
Dan M Posted April 10, 2008 Posted April 10, 2008 I believe my fuel pressure regulator is in need of replacement. MG wants to sell me one for about 250 USD which seems a little pricey... this does include the aluminum adapter that attaches to the tank, but I really just need the regulator. The regulator is a Weber RPM 40. Does anyone know where I could find the Weber part or some other replacement? Thanks, Doug Hey Doug, Why? Is it leaking? If so, where from? There is an o-ring that gets gummed up and can leak. A clean up will fix that. Unless it is leaking from the vacuum port it is probably OK.
Admin Jaap Posted April 10, 2008 Posted April 10, 2008 http://www.v11lemans.com/forums/index.php?showtopic=10463 If I can fix it, everyone can.
Paul Minnaert Posted April 10, 2008 Posted April 10, 2008 If I can fix it, everyone can. well, you can even fix lights
DougInMA Posted April 11, 2008 Author Posted April 11, 2008 Thanks for the replies. There is a slight leak at the regulator and I have cleaned the o-rings. I think what I need to do at this point is check the fuel pressure. On cold mornings last fall, gas started leaking from the fuel injectors. I replaced the o-rings on the injectors, but this did not fix the problem. I was assuming that it might be the regulator. How do I check the fuel pressure? Is there a low cost tool that would allow me to do this? Doug
raz Posted April 11, 2008 Posted April 11, 2008 You can probably buy a very cheap one in an auto store (you'll need a Y junction too) or maybe better borrow a more trusty one at some repair shop. It's not leaking from the bottom of the TB's? Does the engine seem to get a rich mixture?
