Guest ratchethack Posted April 22, 2008 Posted April 22, 2008 Gents! My choice of pet peeves today is none other than one o' the many perennial ignorance/confusions that gets passed around, encouraged, promoted, and proliferated so often here, and elsewhere. Yes, it's time once again to harpoon another great walloping delusion. My objective this morning is to end this particular foolishness here and now -- at least for the time being. Anyone with the most basic understanding of engine operation theory already knows this, but if you don't -- well, I reckon you're long overdue, and there's no time like the present! And no, Binky -- it's not merely a matter of a simple difference in choice of terminology! Coupla things. 1. This can't be re-stated enough, IMHO. Your V11 doesn't have a choke. Chokes are found on carburetors. Your V11 doesn't have one o' those, either. Nor does your car, unless you drive a "vintage" auto of some sort. Your V11 has a lever on the LH handlebar for the purpose of advancing the throttle. This does the same thing as the twist grip on the RH side, but is limited to low throttle openings, and has the advantage of allowing you to "set" it for a period of time while your motor warms up, as opposed to being a "dead man's control" that returns automatically, the way the twist-grip throttle does. 2. Your V11 has Fuel Injection and Throttle Bodies in place of carburetors. This technological advancement is a serious leap beyond the practical limitations of carburetors. Your V11 doesn't need a choke -- and that's a good thing. In a reversal of such historic evolutionary trends as multi-valve, OHC and DOHC motors, which for the most part first became the "norm" with moto's long before such concepts became "mainstream" on auto's (bypassing the V11 altogether ), thanks mostly to chasing better mileage along with performance, the achievement of superior fuel atomization of FI came to moto's far later than it came to auto's -- and for the most part, despite the fact that lots of the aforementioned "advanced technology" skipped over the V11, "allowing" the V11 to remain fundamentally rooted in the relatively crude engine technology of pushrod operated valves, hemispherical heads, and air cooling of a half century ago -- but we can be (arguably) thankful that at least we got FI! Now then. Take a gander at this here garden variety side-draft carb (see immediately below). Wot y'er looking at (the butterfly valve labeled "Choke Plate") is -- astoundingly enough -- a choke. Bears a rather striking resemblance to the butterfly THROTTLE PLATE in your V11's throttle bodies, doesn't it? Yet it could hardly be more different in function, and doesn't work the same way, a-tall! Significantly, chokes on carburetors are located UPSTREAM of the fuel jets in the incoming air flow, whereas your throttle butterfly (or slide, as the case may be) is located farther DOWNSTREAM, either at, or past the point where fuel enters the air stream via the fuel jets. The choke functions to CHOKE OFF air flow when the motor is cranked to start. This creates a higher relative vacuum in the atomization chamber behind the venturi (constriction in carburetor bore), when the motor is cranked to start, rapidly drawing fuel up though the idle circuit and idle jet from the float bowl, and allowing the starting air charge to pick up that fuel and fling relatively large, crude droplets of fuel into the center of the incoming air charge concentrated by the venturi. Poor atomization, but usually "good enough" to get things started so that once rev's build after it's started, and the choke is opened, the device provides fairly adequate atomization of fuel. Pretty crude, eh? Yet this is wot allows carbureted motors far far easier starting than trying to coax that fuel up from the float bowl without the assistance of a choke! Thank Mr. Bernoulli for his contributions to the practical Physics involved in carburetors (there's y'er Italian connection). The "Bernoulli effect" that carburetors depend upon to operate (topic for another discussion) can't happen at the low airflow speeds of starting rev's -- hence the need for the choke. All of the above silliness is obviated entirely on the V11 by fuel injectors, which direct fuel under pressure via a precisely metered (via the ECU) "pulse width" signal worth of far more finely atomized fuel directly into the intake, downstream of the throttle bodies. Makes for relatively quick startups in any weather, at any ambient condition, compared to the relatively finicky carburetor, not to mention allowing the ECU to more accurately regulate the fuel charge by such variables as operating temperature, throttle position, and pre-mapped ignition timing curves -- theoretically without dribbling any fuel anywhere, and most certainly without a choke! Hope this helps. -- Cdr. Hatchracket, Crusty Curmudgeon, thankful enough to have 3 vehicles WITHOUT carburetors and chokes, and lots o' crude garden equipment and such (as well as one moto) with them.
dhansen Posted April 22, 2008 Posted April 22, 2008 Gents! Hope this helps. -- Cdr. Hatchracket, Crusty Curmudgeon, fairly pleased to have 3 vehicles WITHOUT carburetors and chokes, and lots o' crude garden equipment (as well as one moto) with them. Sometimes, I suppose, 'ya just gotta get it out of your system!
belfastguzzi Posted April 22, 2008 Posted April 22, 2008 €£$1 Prize Fund to the first person who can prove Ratchet wrong. C'mon, nothing's impossible.
BRENTTODD Posted April 22, 2008 Posted April 22, 2008 Since were on the subject. My bike seems to have a little of a high idle after the winter. It always idled at about 900 now it about 1800. I checked to see if the high idle lever is stuck nope throttle cables are also free and go back to the proper stop. Has anyone else had this problem Thanks Brent
FuelCooler Posted April 22, 2008 Posted April 22, 2008 €£$1 Prize Fundto the first person who can prove Ratchet wrong. C'mon, nothing's impossible. Ratchet is right. No choke on Fuel Injected V11s or fuel injection period. As a matter of fact, most street (and dirt) bike carbs went to something called an enrichening circut that just added extra fuel via a plunger that was pulled on the carb itself or by a cable attached to said plunger. So those didn't have 'chokes' either (even though they might even have pull knobs with the word 'choke' written on it, like my 1993 CBR 900RR). A choke simulator is more like it. Cheers, Steve
FuelCooler Posted April 22, 2008 Posted April 22, 2008 Since were on the subject. My bike seems to have a little of a high idle after the winter. It always idled at about 900 now it about 1800. I checked to see if the high idle lever is stuck nope throttle cables are also free and go back to the proper stop. Has anyone else had this problem Thanks Brent Come on, man! Did you verify that tach reading with your Snap on tool? It doesn't sound like 1800 to me, but I could be wrong. Carry on, Steve
antonio carroccio Posted April 22, 2008 Posted April 22, 2008 €£$1 Prize Fundto the first person who can prove Ratchet wrong. C'mon, nothing's impossible. Must recon, this foul has got that right. No choke in the V11. It's only a surrogate or helper of the already installed throttle. I am guessing, no prize for me gringo?
BRENTTODD Posted April 22, 2008 Posted April 22, 2008 Come on, man! Did you verify that tach reading with your Snap on tool? It doesn't sound like 1800 to me, but I could be wrong. Carry on, Steve No i havent checked with tool yet (no time you know my old lady the slave driver). It does sound to high to me and if i wack the thottle idle drops down to what sounds normal then rises back up. When i get home from work tonight will idle your bike next to mine and i bet mine sound higher. If i get a chance today ill hock up a tach. Then i will know for sure but i thinks its a little high Good luck and god speed Brent
FuelCooler Posted April 22, 2008 Posted April 22, 2008 No i havent checked with tool yet (no time you know my old lady the slave driver). It does sound to high to me and if i wack the thottle idle drops down to what sounds normal then rises back up. When i get home from work tonight will idle your bike next to mine and i bet mine sound higher. If i get a chance today ill hock up a tach. Then i will know for sure but i thinks its a little high Good luck and god speed Brent You also have that cough at 3000 rpm. You may have a cracked intake boot. Also, we need to set up your TB's and TPS like you have been saying. Isn't your bike nice enough already?!?!
BRENTTODD Posted April 22, 2008 Posted April 22, 2008 You also have that cough at 3000 rpm. You may have a cracked intake boot. Also, we need to set up your TB's and TPS like you have been saying. Isn't your bike nice enough already?!?! No it's not nice enough yet. You know in the automotive world were are nothing less perfect. I am hooking up the tach before we go home today. Ill let you know. Hey you take one ride on by bike now its to nice mister ohlens new frame mounts wide tire carbon fender cool screen. Good luck god speed Brent
coz1100 Posted April 22, 2008 Posted April 22, 2008 to go into it a little more: Choke: blocks air to the motor. AFR goes up Enrichener: adds more full. AFR goes up Fast Idel: ECU takes care of the AFR you just make the idle increase Ciao Z
Gio Posted April 23, 2008 Posted April 23, 2008 I wish my V11 had a choke. And carbs. At least we have a kick starter ... Gio
Guest frankdugo Posted April 23, 2008 Posted April 23, 2008 nobody makes any moola.he's got all the bases covered.
Skeeve Posted April 23, 2008 Posted April 23, 2008 Fine, we don't have a "choke lever" on the bars. And Brits don't carry around "electric torches" either, since a torch is a stick w/ an open flame at the end. Have you got any other mono- or bi-syllabic term for the little lever on the left handlebar that functions like a choke did on a motorcycle w/ carbs that's just been started & is having trouble ticking over on a cold engine? 'Cause we're using that little knob, lever, whatchamajigger like it was a choke lever, so it just kinda pops out that way when speaking or writing about it, even tho' everyone already knows it's a "fast-idle widget."
