gstallons Posted April 26, 2008 Posted April 26, 2008 I went to replace a bulb in the instrument cluster and had to stop. The 8mm nuts would loosen on onside only. The other side, the nuts are stuck on the studs and the nuts were both rotating then they would not tighten back. How do I remove this cover to change the bulb since i have started something that I HAVE to fix. I need your your help!
Guest frankdugo Posted April 27, 2008 Posted April 27, 2008 welllll-its not going to be eassy,&certinaly trying.didyou try to wedge the studs off of the90 deg.get a screwdriver or needlenose behind the nut? failing that,you will have to read the threads on taking them apart. patience-good luck
