nudemetalz Posted April 28, 2008 Posted April 28, 2008 Got the V11 out this morning. Cranked her over and then an almighty backfire went off !! Then she started on only one cylinder. Had a whistling type noise coming from the engine, but thought that just may be one cylinder not running noise. Thought it may just have been a grubby plug so stopped and started again, No clear, so did this a couple of times without it clearing when then it just wanted to rev it's nuts out. Stopped, started again, one cylinder, then copious revs. This is all I need !!! So checked the cables, they're fine. Checked operation of throttle, all good. I give up !!!!!!!!! So, going to call bike shop to come and get her to fix her. Any ideas before I do this? The only thing I did to her last night was a little more oil in the engine (doing the change on the weekend, well was going to) and did the rear diff oil change. Didn't touch anything else. Thanks for any help,
Guest ratchethack Posted April 28, 2008 Posted April 28, 2008 Sounds like the backfire may've wrapped the throttle plate around its shaft on one side. I'd check this first.
nudemetalz Posted April 28, 2008 Author Posted April 28, 2008 Sounds like the backfire may've wrapped the throttle plate around its shaft on one side. I'd check this first. Thanks. Is this a difficult job? (ie anything specific to watch out for)
Guest ratchethack Posted April 28, 2008 Posted April 28, 2008 Thanks. Is this a difficult job? (ie anything specific to watch out for) Not at all difficult to check. Fixin' it is a different matter. Assuming you still have the airbox, loosen the clamp on the rubber intake runner between the TB and the air box on the side that backfired, and carefully break the seal at the TB. They can be stubborn, and are prone to crack if you're not careful. Then just slide the intake runner back into the air box and have a gander at the throttle plate. A small mirror may help. If the plate is bent, it'll be pretty obvious. If so, you have a relatively low-cost (if'n you don't break anything, possibly $0 ), but semi-finnicky, quasi-high effort project to get that bent plate out, get it as straight as possible again, and re-installed. A balance of the TBs will certainly be in order. No way I can see to get the plate out for straightening without having the TB off the bike. Not too tough, though. Good luck. Any more Q's, post 'em here.
nudemetalz Posted April 29, 2008 Author Posted April 29, 2008 Thanks for help. It has been running a little rough down low lately and was in need of a tune so I might just give this to the shop as I really don't want to break anything on my pride and joy.
jtucker Posted April 29, 2008 Posted April 29, 2008 or blown the TB out of the boot. My thoughts exactly. I've had that happen more than once. __Jason
docc Posted April 29, 2008 Posted April 29, 2008 or blown the TB out of the boot. And this is easy to fix: loosen the clamp, push the boot on, tighten the clamp. The tune-up will keep it from happening again. Look down at the throttle body to see if one has pulled back off the head.
nudemetalz Posted April 29, 2008 Author Posted April 29, 2008 And that's exactly what it was. The RHS TB blew out of the intake boot. So, loosened all the clamps, pushed it back in, retightened and she's a goer !!! I really would not have expected to have to look there,......only Guzzi's ay !!! Thanks for all your help, guys !!!
dangerous Posted April 29, 2008 Posted April 29, 2008 yeah ya silly wellingtonion... check the TB pound to a knob a goat shit thats the prob
dangerous Posted April 29, 2008 Posted April 29, 2008 ahh ya see I was right... hey you posted at the same time as me, thats not possible you are in a different time zone
nudemetalz Posted April 29, 2008 Author Posted April 29, 2008 That's 'cause us North Islanders are an hour ahead.......
dabore84 Posted April 29, 2008 Posted April 29, 2008 those abbreviations are killing me, what dou you mean with TB.
