Have motor/trans split. It appears from parts book that I can remove & replace clutch pushrod from clutch end w/o losing location on any seals or it being difficult to relocate at piston end. Is that right?
I want to fit a new pushrod seal.
Thanks,
KB :sun:
you just can take the rod out, thats easy, it will drop out if you don't watch it. You can unsrew the 3 screws on the cylinder at the back of the gearbox.
Thanks Paul. I have motor out but trans & s/a are still in place, going to pull the rod out from clutch end, just checking no location problems when putting it back in...ie: no seals to drop off or location piece at piston end tilting etc.
KB :sun:
