Guest MARK MCGLEISH Posted May 1, 2008 Posted May 1, 2008 Dear all I have a 2005 Scura R with the standard bars. I really like the more sporty lower bars you see on some bikes e.g. the V11 le mans I have seen. How do you make the change, is it simply buying new bars or is there more to it ?. Not a mechanical kind of guy normally so apologies if this is a bit daft. Cheers Mark
tripletom Posted May 7, 2008 Posted May 7, 2008 On my 02 Scura I have clip-ons instead of the top yoke mounted bars you have, so I would suggest purchase of clip-ons to suit your fork diameter and then swap all the controls over, then remove the bar clamps from the top yoke.
Guest MARK MCGLEISH Posted May 7, 2008 Posted May 7, 2008 tripletom said: On my 02 Scura I have clip-ons instead of the top yoke mounted bars you have, so I would suggest purchase of clip-ons to suit your fork diameter and then swap all the controls over, then remove the bar clamps from the top yoke. Thanks mate for replying.
