Ryland3210 Posted May 2, 2008 Share Posted May 2, 2008 Does the Jackal use the same "pork chop" side bracket the footpegs are mounted to? Thanks. Link to comment Share on other sites More sharing options...
jtucker Posted May 2, 2008 Share Posted May 2, 2008 Does the Jackal use the same "pork chop" side bracket the footpegs are mounted to? Thanks. It would appear not. Different frame: __Jason Link to comment Share on other sites More sharing options...
Guest ratchethack Posted May 2, 2008 Share Posted May 2, 2008 Wot Jason said. The Jackal is a Tonti frame. Link to comment Share on other sites More sharing options...
Ryland3210 Posted May 2, 2008 Author Share Posted May 2, 2008 Thanks for the quick reply. Now that I think of it, does the Jackal use the same banjo fitting to feed oil to the heads? I learned that the Centauro uses a 10 mm instead of 8 mm. What about the Jackal? Link to comment Share on other sites More sharing options...
Greg Field Posted May 2, 2008 Share Posted May 2, 2008 8mm on all the 2VPC big blocks. Link to comment Share on other sites More sharing options...
Ryland3210 Posted May 3, 2008 Author Share Posted May 3, 2008 8mm on all the 2VPC big blocks. Thanks, Greg. It's kind of you to chime in. Does that mean that anything less than 1100 would have 10 mm screws? Link to comment Share on other sites More sharing options...
