dlaing Posted May 25, 2008 Author Share Posted May 25, 2008 I have not installed a plate yet. With a new filter I put in 4qts. Never had a problem with light comming on. I don't do alot of hard starts because of no plate. Is this too much oil to run? As I understand it, there are two possible problems with running it too high: The first problem is that the oil could start blowing excessively into the airbox, causing excessive consumption and some oil leaking out of the airbox, on the left side where the throttle body connects. If you add a windage/sloppage sheet/plate, the reduced windage will reduce the chance of that happening. The second problem is that the increased level reduces the air space which increases the air pressure pulses as the cylinders approach Bottom Dead Center, and the increased air pressure pulses cause the seals to leak. Also, it can theoretically cause a reduction in power. I don't think we have heard of any seals leaking at 4 quarts, and some people are apparently running the oil level up to the bottom of Pete's sloppage sheet, which might be about 5 quarts, and still no reports of blown seals. And there has been no evidence of any reduction in power, and in fact there have been a couple reports of the sensation of more power after installing Pete's sloppage sheet and presumably running the oil at a higher than the high mark on the dipstick. Link to comment Share on other sites More sharing options...
quazi-moto Posted June 1, 2008 Share Posted June 1, 2008 I just scored a Roper knock-off, but I must say its a beautifully machined piece of stainless. Now, where's the best source for the requisite gaskets that will be involved and how much oil should I run in the sump? Link to comment Share on other sites More sharing options...
twhitaker Posted June 1, 2008 Share Posted June 1, 2008 Any of the usual suspects would have the gasket. Moto International, MPH, MG Cycle, Fast by Ferraci, Eish, Uncommon, Harpers. It's the same one used in the Tonti models since '74. I believe you can put in an extra quart of oil. That should bring the level to just below the plate. Link to comment Share on other sites More sharing options...
pete roper Posted June 1, 2008 Share Posted June 1, 2008 I just scored a Roper knock-off, but I must say its a beautifully machined piece of stainless. Now, where's the best source for the requisite gaskets that will be involved and how much oil should I run in the sump? If you can't find Greg's instructions here they are hosted on the Guzzitech dk site. Pete Link to comment Share on other sites More sharing options...
gstallons Posted June 2, 2008 Share Posted June 2, 2008 I just scored a Roper knock-off, but I must say its a beautifully machined piece of stainless. Now, where's the best source for the requisite gaskets that will be involved and how much oil should I run in the sump? Marsh Motorcycle is probably the closest 860-623-7795 Link to comment Share on other sites More sharing options...
dabore84 Posted June 2, 2008 Share Posted June 2, 2008 I need a sheet too, but Pete wont send me the how to order info I couldn't find it anywhere and I DID search a lot. Or do I mis something. Pete send me the info Link to comment Share on other sites More sharing options...
pete roper Posted June 2, 2008 Share Posted June 2, 2008 I need a sheet too, but Pete wont send me the how to order info I couldn't find it anywhere and I DID search a lot. Or do I mis something. Pete send me the info Mate, I wondered what happened. I did reply in a PM with my contact details etc but recieved no reply. Having said that I have a feeling that my 'Clever' 14 year old son has been trying to hide the fact he's been downloading cyber-porn from his parents and this has stuffed up our computer settings a bit so my message may well of gone AWOL! Anyway, my email is motomoda optusnet.com.au with the *at* substituted with the ampersand of course Try that, and hopefully your inbox won't fill up with pictures of girls with unfeasibly large bossoms! Pete Link to comment Share on other sites More sharing options...
dabore84 Posted June 2, 2008 Share Posted June 2, 2008 Mate, I wondered what happened. I did reply in a PM with my contact details etc but recieved no reply. Having said that I have a feeling that my 'Clever' 14 year old son has been trying to hide the fact he's been downloading cyber-porn from his parents and this has stuffed up our computer settings a bit so my message may well of gone AWOL! Anyway, my email is motomoda optusnet.com.au with the *at* substituted with the ampersand of course Try that, and hopefully your inbox won't fill up with pictures of girls with unfeasibly large bossoms! Pete LOL, it brings back memories when I also dl porn from a dail up line (a bill of 200 dollars in 2 weeks). I think at age 15. Told my parents I was looking for some nba stuff. I'll send you a mail ASAP. I need to change the oil soon (10000km service). Link to comment Share on other sites More sharing options...
dlaing Posted August 11, 2008 Author Share Posted August 11, 2008 Just thought I would update that my Oil Consumption appears to be down remarkably! Less oil is collecting in left side of airbox, and the oil took 2000 miles to get a little below the high mark on the dipstick. It is possible it got to that level miles ago, and it has stabilized. I am guessing consumption has been cut in half, saving me maybe $10 per year I am very happy! Thanks Pete R.!!! (and all the others that have testified to the success of using a schloppage shleet.) If you don't have a sloppage sheet, you should get one of Pete's or make your own! Link to comment Share on other sites More sharing options...
