mznyc Posted May 20, 2008 Posted May 20, 2008 finally got all the stripped bolts out of the rear hub.Now how to remove the bearings.Does the circlip on the left hand side need to come off to the remove bearings? Thanks
Tom M Posted May 21, 2008 Posted May 21, 2008 Yup you need to pull the circlip. As was mentioned in another thread you did not have to remove the cush drive plate, but since you did you should consider removing half the rubbers and maybe even drilling the remaining ones. I think both Pete Roper and Greg Field recommended this in the past. I did it and I think it does really help smooth out the shifting. Wait a minute...I saved the link somewhere...here it is! http://www.v11lemans.com/forums/index.php?showtopic=11820
mznyc Posted May 21, 2008 Author Posted May 21, 2008 Yup you need to pull the circlip. As was mentioned in another thread you did not have to remove the cush drive plate, but since you did you should consider removing half the rubbers and maybe even drilling the remaining ones. I think both Pete Roper and Greg Field recommended this in the past. I did it and I think it does really help smooth out the shifting. Wait a minute...I saved the link somewhere...here it is! http://www.v11lemans.com/forums/index.php?showtopic=11820 Thanks Tom!
