It's hard to be humble...
Yeah, yeah, stop showing off, just cause some of us aren't quite so well equipt as you.....! :P
With some lightening and balancing, I'm sure they could coax 1 or 2 more RPM out of it.
I wonder if it needs a sloppage plate to handle acceleration forces...
__Jason
A roper plate would add a lot of weight. On the other hand, overfilling the sump 25% would probably too... let's just hope they didn't put the pickup at the front.
I'd like to see the oil filter! :o
Guest frankdugo
i would'nt want to change it
This picture lies! I followed the link, these are japanese people giving size to the shaft.
Hubert
or put the hose clip on it to stop it coming loose :D
That engine probably has a separate hydraulic unit for supplying the lubrication to the system. 100 HP 300 gallons. Dual filters so the dirty one can be cleaned while the other is being used. I'll bet those filters are the size of garbage cans.
