I have a set of these bearings to reduce the steering head angle. They came with some Italian instructions that i stuck into a web translator. Can someone interpret this for me ?
Prima Del Montaggio Forcella Tagliare 2/3mm
Fine corsa della base forcella
Prima di mont are il cuscinetto inferiore tagliare o smerigliare 2/3 mm
le appendici fine corsa sterzo
if anyone has installed one of these on a V11 could they tell me if 2-3mm needs to be removed from the
underside of the forward surface of the top clamp and 2/3 mm of the rearward upper face of the lower triple clamp ?
Cheers
Bruce
