Guest BIGGERJIM Posted June 28, 2008 Posted June 28, 2008 hello yall my 2001 v11 was idling to low after a tb and tps adj months ago. but was performing fine. so i decided to adjust it today, after a ride, and of course when i turned the idle up the tps got off. so i went thru the whole process agian got the tps at 521mv at idle got everything balanced and now it will all of the sudden just cut off when idling. at idle the tps is at 521mv, and the idle is at 1100 or 1200 per the tach. but i will cut off at will. i really should have left it alone. but i want my guzzi right. any suggestions would be appreciated. thank big jim
richard100t Posted June 29, 2008 Posted June 29, 2008 You didnt turn the white plastic knob to adjust the idle did you?
raz Posted June 29, 2008 Posted June 29, 2008 If you want to increase the idle speed of a perfectly tuned bike without altering TPS and stuff at all, the party trick is to give more air bleed only. You'd want to have synch gauges connected though. That being said, you could have just raised the idle speed using LH idle screw and considered yourself done. If the bike was running fine, why would you want to mess with the rest? The target is not 521 mV. The target is a bike running fine!! No bashing intended, just food for thought
Guest BIGGERJIM Posted June 29, 2008 Posted June 29, 2008 If you want to increase the idle speed of a perfectly tuned bike without altering TPS and stuff at all, the party trick is to give more air bleed only. You'd want to have synch gauges connected though. That being said, you could have just raised the idle speed using LH idle screw and considered yourself done. If the bike was running fine, why would you want to mess with the rest? The target is not 521 mV. The target is a bike running fine!! No bashing intended, just food for thought thanks fellows i will iron it out tommorow thanks big jim
