Guest BIGGERJIM Posted July 2, 2008 Share Posted July 2, 2008 hey yall i was trying to get the rear axle nut off my v11 to grease the u-joints and i can't seem to get the axle nut loose, i pure lifted the rear of the bike up trying to break it loose. i hope the bearing have survived the incredable torque they have been under is it normal for them to be this tight. is there something i'm messing beside the big axle nut. thanks big jim Link to comment Share on other sites More sharing options...
Tom M Posted July 2, 2008 Share Posted July 2, 2008 is there something i'm messing beside the big axle nut. Did you remove the little rubber plug and put an allen wrench into the right side of the axle? Link to comment Share on other sites More sharing options...
Baldini Posted July 2, 2008 Share Posted July 2, 2008 Have you tried shocking it .... ? (sharp tap with something heavy on end of spanner/socket)...better than torque for loosening overtight/seized nuts... KB Link to comment Share on other sites More sharing options...
Guest BIGGERJIM Posted July 2, 2008 Share Posted July 2, 2008 i even tried the impact wrench while holding the allen wrench on the other side is there a pinch bolt i'm not seeing i picked up the back of the bike with a pry bar on the wrench. boy lubing them u-joints are gonna be a pia . thanks Link to comment Share on other sites More sharing options...
FuelCooler Posted July 2, 2008 Share Posted July 2, 2008 i even tried the impact wrench while holding the allen wrench on the other side is there a pinch bolt i'm not seeing i picked up the back of the bike with a pry bar on the wrench. boy lubing them u-joints are gonna be a pia . thanks I would try heating the nut with a torch. It may have been assembled with loctite red. If that doesn't work, I would try even more heat. Be careful with the paint on the swing arm. Good luck, I think you will get it off. Cheers, Steve Link to comment Share on other sites More sharing options...
Guest BIGGERJIM Posted July 2, 2008 Share Posted July 2, 2008 hey yall i broke it, but i had to whack it with a hammer and get a very long pry bar but i broke it loose, after supper i'M going to finish tearing it down, and attack them u-joints THANKS FOR THE HELP YALL ALWAYS COME THRU BIG JIM Link to comment Share on other sites More sharing options...
savagehenry Posted July 3, 2008 Share Posted July 3, 2008 i picked up the back of the bike with a pry bar on the wrench. thanks So thats why they call ya BIGGERJIM! Link to comment Share on other sites More sharing options...
