slug Posted July 4, 2008 Posted July 4, 2008 When checking valve clearance with feeler gauges, how do you tell when the clearance is right? Should the feeler gauge go freely between the rocker and the valve, or should there be a slight resistance? I've done my valves many times before and always went with a slight resistance (that's what I was taught back in my welder/fitter days), but I'm curious what other people think/do.
Baldini Posted July 4, 2008 Posted July 4, 2008 When it feels like it's sliding on both surfaces but not pinched. KB
dlaing Posted July 5, 2008 Posted July 5, 2008 When it feels like it's sliding on both surfaces but not pinched. KB Well put! I have probably aimed for tiniest amount of pinch that I can detect, but technically I think Baldini is more correct. The old dogs tale is to equate pulling through a dictionary, but that is too variable and implies some pinch. I verify my methodology by going one smaller and one tighter. One smaller should feel too loose, and one bigger should not fit...assuming a difference of gauges of 0.05mm (.002") or greater. Be sure your pull is parallel. Be sure to use good, not too battered and not too corroded gauges, and verify at different places on the gauge. It does not have to be perfect. Just don't mess up and set it at the wrong TDC position.
Lex Posted July 5, 2008 Posted July 5, 2008 I'll add something I learned from a very experienced BMW mechanic years ago: When you take the reading push down on the end if the rocker opposite the valve. There are a a lot of places that can have some slop (cam to follower, follower to push rod, push rod to rocker) and throw the reading off. Once you do that Baldini's description of the feel of the of the feeler gauge is pretty good.
dlaing Posted July 5, 2008 Posted July 5, 2008 I'll add something I learned from a very experienced BMW mechanic years ago: When you take the reading push down on the end if the rocker opposite the valve. There are a a lot of places that can have some slop (cam to follower, follower to push rod, push rod to rocker) and throw the reading off. Once you do that Baldini's description of the feel of the of the feeler gauge is pretty good. Thanks! That makes perfect sense! (and may explain why my readings go off so fast )
slug Posted July 5, 2008 Author Posted July 5, 2008 Thanks all. Great advice on pushing down on the opposite side of the rocker. Someone mentioned that somewhere on this forum many moons ago, and I've done it ever since.
Molly Posted July 5, 2008 Posted July 5, 2008 Thanks all. Great advice on pushing down on the opposite side of the rocker. Someone mentioned that somewhere on this forum many moons ago, and I've done it ever since. Helps to have three hands. I also need to find a tool to hold things in place whilst I tighten it up. I always move it just enough to have to do it again... Doh!
Dan M Posted July 5, 2008 Posted July 5, 2008 "Go / No-go" is an easy check. Set it to spec with light drag. Check it with the next size up. Should be quite tight. The next size down should be very loose. No need to do every valve like this but you will get the "feel" for what is right after checking a couple. edit: This assumes you have a feeler gauge set, not just the spec sizes.
tmcafe Posted July 5, 2008 Posted July 5, 2008 Helps to have three hands. I also need to find a tool to hold things in place whilst I tighten it up. I always move it just enough to have to do it again... Doh!Holding the adjusting screw in place is bit awkward. I used a smaller adjustable wrench, but later somebody gave me a 1/8" mini wrench (Snap-on), which should fit the screw head.
tmcafe Posted July 5, 2008 Posted July 5, 2008 edit: This assumes you have a feeler gauge set, not just the spec sizes.I have a metric set, but the specs I used (Micha's best recommendation) aren't among the blades, so I "cheated" by adding two blades to match. I wonder if some of the inch sets have a close match.
audiomick Posted November 3 Posted November 3 (edited) I know this thread is old enough to be classed as antique, but I just stumble across it, and I did two lots of valve clearances in the last week or so, and thought about what I was doing. So... On 7/5/2008 at 1:34 PM, Molly said: Helps to have three hands. I also need to find a tool to hold things in place whilst I tighten it up. What I ended up with, which works for me really well (I am right-handed): A ring spanner on the lock-nut on the adjustment screw. Screwdriver in the left hand on the adjustment screw. Feeler gauge in the right hand. Back off the lock nut until the adjustment screw just turns. Rest the ring-spanner on the knuckles of the right hand. If it locks up, you can easily back it off a bit just by raising the hand a bit. Feeler gauge in the gap, and turn the screw back and forth with the screwdriver to find the gap. When you have it, drop the right hand a bit, and the weight of the ring spanner tightens the lock nut a bit automatically. If the last movement of the screwdriver was in the direction of "looser", it has already taken up the play in the screw head slot, and a steady hand should be able to hold it there whilst tightening the lock nut. Feeler gauge out, letting the ring spanner (carefully) fall in the process, and then nip it up tight. I hope that is not too cryptic. I don't have a film of the process... Edited November 3 by audiomick 1
Chuck Posted November 3 Posted November 3 I was showing my pup Austin how to adjust valves a few years ago. I told him you want it to feel like it would if you put it near the spine of a phone book, closed it, then pulled the feeler gauge out. He said, "Phone book?" 2 5
gstallons Posted November 3 Posted November 3 My personal method on valve clearance adjustment : tighten the adjusting screw until the feeler gauge will not move , Loosen the screw until the feeler gauge slides out , holding the screw in place then tighten the adjusting nut until it is snug AKA not coming loose . then I am happy. 2
p6x Posted November 3 Posted November 3 (edited) How accurate are the feeler gauges you use anyway? Was there a metrological check included with them? I think they are mass produced so the entire procedure is kind of relative anyway. Its rather an approximation exercise. Not withstanding the temperature at which you are using them. Usually, properties are measured at standard conditions. https://en.wikipedia.org/wiki/Standard_temperature_and_pressure Lol.... Edited November 3 by p6x 2
