techlusion fuel injection module
Guest Petev11
i would like to instal a ring teminal harnes for my battery tender, does any body know if disconnecting the battery will affect the bikes fuel injection module? or can i just reconnect the battery and go ?
p.s. the module is manufactured by[ techlusion] not power commander
I am 99% sure you can simply disconnect and reconnect the battery.
It is not a problem for the ECU or the PCIII.
The Techlusion only loses its settings if someone turns the screws, although I am sure a lightning bolt could mess up the settings :P
Be sure to remember that when disconnecting battery, disconnect negative first and positive second. When reconnecting battery, connect positive first and negative second.
