tmcafe Posted July 9, 2008 Posted July 9, 2008 Checking my rear caliper, I was looking at the sealed bearing right next to the caliper bracket. Sure it's sealed, but wondering if being exposed to so much road dirt doesn't affect it at all. AFAIK, there's also nothing between the alu caliper bracket and this bearing (the only large washer is under axle nut, the other end protects the needle bearing). Did any anybody think of somehow protecting the bearing other than keeping its surface reasonably clean?
Baldini Posted July 9, 2008 Posted July 9, 2008 It's pretty normal that m/c wheel brngs are exposed. Generally they last OK. I wouldn't worry about it. KB
nose2wind Posted July 9, 2008 Posted July 9, 2008 Checking my rear caliper, I was looking at the sealed bearing right next to the caliper bracket. Sure it's sealed, but wondering if being exposed to so much road dirt doesn't affect it at all. AFAIK, there's also nothing between the alu caliper bracket and this bearing (the only large washer is under axle nut, the other end protects the needle bearing). Did any anybody think of somehow protecting the bearing other than keeping its surface reasonably clean? I make it a habit of checking that bearing (all wheel bearings) every time I change the tire. That left side rear bearing is prone to failure. I was left stranded in Ozark when I noticed the bike was handling funny (wobbly in corners). I looked down and could see the steel balls some missing inside the dry races. The outside seal was completely gone! D
tmcafe Posted July 10, 2008 Author Posted July 10, 2008 I make it a habit of checking that bearing (all wheel bearings) every time I change the tire. That left side rear bearing is prone to failure. I was left stranded in Ozark when I noticed the bike was handling funny (wobbly in corners). I looked down and could see the steel balls some missing inside the dry races. The outside seal was completely gone! D Crap! Probably a good idea to keep an eye on that seal and keep it clean. If it's exposed, at least it's easy to check.
