tmcafe Posted July 16, 2008 Author Share Posted July 16, 2008 Thanks guys! Seems that turning the LH idle screw is the thing to try, which Micha also suggested. However, as the manual says, will that include balancing the TBs ? (I've got a Twinmax) Funny thing is, the more I'm working out these little glitches, the more I love this bike. This forum has played a good part too... Link to comment Share on other sites More sharing options...
Tom M Posted July 16, 2008 Share Posted July 16, 2008 Thanks guys! Seems that turning the LH idle screw is the thing to try, which Micha also suggested. However, as the manual says, will that include balancing the TBs ? (I've got a Twinmax) Funny thing is, the more I'm working out these little glitches, the more I love this bike. This forum has played a good part too... Nope again. Once the throttle bodies are balanced there's no need to do it again just because you cranked up your idle a few hundred rpm. Link to comment Share on other sites More sharing options...
tmcafe Posted July 16, 2008 Author Share Posted July 16, 2008 Nope again. Once the throttle bodies are balanced there's no need to do it again just because you cranked up your idle a few hundred rpm.Sounds good Tom, thanks! Link to comment Share on other sites More sharing options...
