I got a set of the factory saddlebags for my Rosso, but no instructions for installation of the mounts. Can somebody give me some help on this? I can see where the front brackets need to go, but the smaller ones in the back have me baffled. Thanks!
Some longer screws under the fender panel anchor the small bands. I can take some pictures if you need them . . .
Here's one I did earlier
I didn't use the long spacer tubes (top front). I thought they'd want to sit in the foot rest hanger and was too big to do so, and not big enough to be convincing to sit proud. Also didn't seem to line up very well.
Then there's the front bottom - inside or outside of the hanger/ exhaust bracket.
The back is the only one that's easy provided you haven't had your mudguard eliminated :)
There's some give in the wire frame design.
I did have one of the welds pop, had it rewelded with a bit of bracing.
