STEELPULSE Posted August 13, 2008 Share Posted August 13, 2008 I hope I have the right name for it, checking tire pressure this morning and noticed a crack in the gray housing on the right side of my rear wheel. There is no oil leaking out from this though I see a drain plug on it. At the expense of sounding very uninformed, how common is this ? and what is the fix?. Thanks for your inputs Link to comment Share on other sites More sharing options...
Guest frankdugo Posted August 13, 2008 Share Posted August 13, 2008 I hope I have the right name for it, checking tire pressure this morning and noticed a crack in the gray housing on the right side of my rear wheel. There is no oil leaking out from this though I see a drain plug on it. At the expense of sounding very uninformed, how common is this ? and what is the fix?. Thanks for your inputs it is not a common problem that i am aware of.i presume it is above half way up since you say no leak's.you could wait to see if it get's worse,or to prevent failure jb weld it--or take it off to weld.good luck,let us know what is happening Link to comment Share on other sites More sharing options...
Paul Minnaert Posted August 13, 2008 Share Posted August 13, 2008 not common, please post a detail picture. Depends if it's an area where force is on or not if you need to replace it. Link to comment Share on other sites More sharing options...
STEELPULSE Posted August 13, 2008 Author Share Posted August 13, 2008 not common, please post a detail picture. Depends if it's an area where force is on or not if you need to replace it. Thanks for the responses guys, I will post a picture when I get home tonite since I did not ride it to work today Link to comment Share on other sites More sharing options...
STEELPULSE Posted August 18, 2008 Author Share Posted August 18, 2008 Well it looks like a bolt some how came loose from behind and fell into the outer none oil carrying section of the rear diff while riding causing the crack..:-( Link to comment Share on other sites More sharing options...
Paul Minnaert Posted August 19, 2008 Share Posted August 19, 2008 well oil or not, some parts do have a lot of stress, and might be a security issue if notting done to it. Link to comment Share on other sites More sharing options...
raz Posted August 19, 2008 Share Posted August 19, 2008 You are sure there is a crack in the casing itself and not just the painting? I think if you have a crack through it would leak lots of oil regardless of if it's above the oil level or not. Link to comment Share on other sites More sharing options...
Paul Minnaert Posted August 19, 2008 Share Posted August 19, 2008 raz, there is a part that has no oil and no direct function, here it's taken of. So if its in the part I tookoff, no wory, else there is a problem. Link to comment Share on other sites More sharing options...
STEELPULSE Posted August 20, 2008 Author Share Posted August 20, 2008 raz, there is a part that has no oil and no direct function, here it's taken of. So if its in the part I tookoff, no wory, else there is a problem. I was not able to get a pix before taking it to my local dealer. but he crack is in the lower area between the drain plug on the left side and the bubble just above it in your photo. Link to comment Share on other sites More sharing options...
Guest frankdugo Posted August 21, 2008 Share Posted August 21, 2008 well oil or not, some parts do have a lot of stress, and might be a security issue if notting done to it. from you'r saying its on the housing body,i think paul is correct.if it was on my bike i would have it welded Link to comment Share on other sites More sharing options...
raz Posted August 21, 2008 Share Posted August 21, 2008 That looks pretty neat Paul. More like a carb Sport bevelbox. Is there room for a cush drive in your rear wheel? I've always thought that flange is too big, aestethically. Link to comment Share on other sites More sharing options...
