FE-427 Posted August 14, 2008 Share Posted August 14, 2008 I need to get some heads done Basically I need to get the chamber welded up similar to a Branch head. Also I need the heads flowed with bigger valves...Any clues where I can get this done? 2000 V11 Sport Thanks in advance Link to comment Share on other sites More sharing options...
Dan M Posted August 14, 2008 Share Posted August 14, 2008 I need to get some heads done Basically I need to get the chamber welded up similar to a Branch head. Also I need the heads flowed with bigger valves...Any clues where I can get this done? 2000 V11 Sport Thanks in advance Here: http://www.mikerichmotorsports.com/ Call him up, I'm sure he'll be happy to talk with you about it. Link to comment Share on other sites More sharing options...
dlaing Posted August 15, 2008 Share Posted August 15, 2008 Did you talk to Branch Flowmetrics to see if they would do a Guzzi? http://www.branchflowmetrics.com/ Link to comment Share on other sites More sharing options...
FE-427 Posted August 15, 2008 Author Share Posted August 15, 2008 Thanks for the links I was calling the old number from the Guzzi Tech page and got worried I have known Jerry Branch since the mid 80's and learned a lot about flow dynamics from him. Probably just enough to screw things up, but at any rate the ownership has changed and all you get is an answering machine.. I will keep trying.. I am just not sure if Mike would do the weld up to a bath tub style head. I would prefer that he does the heads but we will see.... Thanks again .. Cheers Link to comment Share on other sites More sharing options...
Skeeve Posted August 15, 2008 Share Posted August 15, 2008 Thanks for the linksI was calling the old number from the Guzzi Tech page and got worried I have known Jerry Branch since the mid 80's and learned a lot about flow dynamics from him. Probably just enough to screw things up, but at any rate the ownership has changed and all you get is an answering machine.. I will keep trying.. I am just not sure if Mike would do the weld up to a bath tub style head. I would prefer that he does the heads but we will see.... Thanks again .. Cheers I think he'll do it, but from email with him about the same idea, I know he'll recommend just getting a set of his pistons, which will actually match the v11 head contours properly to provide squish [which the stock & FBF pistons do not.] Basically, it provides 50% of the performance of what you're trying to do for 25% of the price. Anyway, talk to him, I'm sure he'll be willing to at least discuss what you're trying to achieve & the best way to go about it. Me, I'd like a properly designed modern combustion chamber too, instead of the 40's era one under a pile of band-aids we've got now... Link to comment Share on other sites More sharing options...
dlaing Posted August 17, 2008 Share Posted August 17, 2008 Basically, it provides 50% of the performance of what you're trying to do for 25% of the price. Twin-Plugging, re-mapped fueling, re-mapped ignition, a cam, and some porting, and you may be at 150% But yah, reshaping the combustion chamber with all those other options could get you close to a drivable 100RWHP Anders is making 99HP edit 80HP with simple mods, and our beloved Admin, Jaap, is making over 90HP, see both dynos here, with just muffler, x-over, and pods, so it is certainly possible. Link to comment Share on other sites More sharing options...
raz Posted August 17, 2008 Share Posted August 17, 2008 Anders is making 99HP with simple mods No that was Peter from Austria. He got 99 HP from his 1040cc LM3 but he hasn't told how he achieved that - and to what cost... Link to comment Share on other sites More sharing options...
dlaing Posted August 17, 2008 Share Posted August 17, 2008 No that was Peter from Austria. He got 99 HP from his 1040cc LM3 but he hasn't told how he achieved that - and to what cost... My error! I was reading the sequence of discussion without paying attention to poster's name. Anders got a more realistic 80.3HP Thanks! When is Pierre from San Diego going to do a write up on his 99HP Mike Rich modified machine? He keeps posting about Stoners and stuff... Link to comment Share on other sites More sharing options...
Darius Posted August 19, 2008 Share Posted August 19, 2008 Mike Rich is very much in the business in his new shop in Newfoundland, PA - great ride through some twisties to get there to boot! I concur with the other's comments regarding his pistons as my bike has been running excellent with absolutely no hint of detonation during the hottest summer days (note: I am about to post a rough running issue that does not have anything to do with Mike's work). FWIW - we got 82 peak rear wheel HP on Mike's conservative dyno after rebuilding the motor with his pistons, stage 1 porting, larger valves, Megacycle cam, PC III and factory Ti cans. My request was for very usable mid-range power which I got, but the bike pulls hard to redline in every gear. In case you don't have his reach number, its (570) 676-4785. Link to comment Share on other sites More sharing options...
