kadavere Posted November 12, 2008 Posted November 12, 2008 Heres one that I found somewhereCali 1100 no modifications Hope its useful Static Config TDC=0x1c00, CylOffs=270, PulsesPer=32, MissingPulses=0,CoilCharge0=6000,CoilCharge1=2500 My16M Config RPM=8064, O2=124, TPS=100, ColdBoost=1300, WarmBoost=0, InjPos=330 THR 924 924 924 924 768 640 512 448 384 320 256 192 128 64 0 RPM 500 1000 1500 2000 2500 3000 3501 4002 4501 5000 6000 7009 8012 8012 8012 8012 SpkAdv 14 5.27 11.95 20.39 22.15 24.26 28.13 27.07 27.77 32.34 35.16 35.16 33.05 30.23 30.23 30.23 30.23 SpkAdv 13 5.27 11.95 20.39 22.15 24.26 28.13 27.07 27.77 32.34 35.16 35.16 33.05 30.23 30.23 30.23 30.23 SpkAdv 12 5.27 11.95 20.39 22.15 24.26 28.13 27.07 27.77 32.34 35.16 35.16 33.05 30.23 30.23 30.23 30.23 SpkAdv 11 5.27 11.95 20.39 22.15 24.26 28.13 27.07 27.77 32.34 35.16 35.16 33.05 30.23 30.23 30.23 30.23 SpkAdv 10 5.27 11.25 20.39 24.26 25.31 28.13 29.88 30.94 31.64 34.45 35.16 34.45 30.23 30.23 30.23 30.23 SpkAdv 09 5.27 10.20 18.63 22.85 25.31 29.53 30.94 30.59 32.34 34.80 35.16 35.16 31.29 31.29 31.29 31.29 SpkAdv 08 5.27 10.20 18.63 25.31 27.07 31.64 34.10 35.86 37.27 39.38 40.08 37.97 37.27 37.27 37.27 37.27 SpkAdv 07 5.27 9.14 16.17 22.50 25.31 30.59 33.75 36.21 38.67 39.73 41.13 40.08 39.38 39.38 39.38 39.38 SpkAdv 06 5.27 7.03 14.06 20.39 24.26 30.59 34.45 38.67 40.78 41.13 42.89 42.19 40.78 40.78 40.78 40.78 SpkAdv 05 5.27 5.27 13.71 20.39 23.20 31.29 36.21 40.78 42.19 43.24 44.30 43.24 42.89 42.89 42.89 42.89 SpkAdv 04 5.27 5.27 13.36 21.80 25.31 31.64 37.62 41.48 43.59 44.30 45.00 44.30 44.30 44.30 44.30 44.30 SpkAdv 03 5.27 5.27 12.66 22.50 26.72 34.10 39.38 43.24 44.65 45.00 45.70 44.65 44.65 44.65 44.65 44.65 SpkAdv 02 5.27 5.27 12.66 24.26 28.13 36.21 40.08 43.59 45.00 46.41 46.41 46.41 45.70 45.70 45.70 45.70 SpkAdv 01 5.27 5.27 12.66 25.31 29.18 36.21 41.48 44.30 46.41 47.11 47.11 46.76 46.41 46.41 46.41 46.41 SpkAdv 00 5.27 6.68 2.81 5.27 15.47 41.13 45.00 48.16 49.57 50.27 50.27 50.27 50.27 50.27 50.27 50.27 RPM 500 1000 1500 2000 2500 3000 3501 4002 4501 5000 6000 7009 8012 8012 8012 8012 InjDur 14 5000 12464 12336 11872 11600 11168 11536 11088 11024 10768 13088 12768 12384 12384 12384 12384 InjDur 13 5000 12464 12336 11872 11600 11168 11536 11088 11024 10768 13088 12768 12384 12384 12384 12384 InjDur 12 5000 12464 12336 11872 11600 11168 11536 11088 11024 10768 13088 12768 12384 12384 12384 12384 InjDur 11 5000 12464 12336 11872 11600 11168 11536 11088 11024 10768 13088 12768 12384 12384 12384 12384 InjDur 10 5000 12272 12080 11600 11408 10848 11040 10896 10624 10448 11264 10864 11088 11088 11088 11088 InjDur 09 5000 11808 11616 11488 11008 10608 10416 9632 8640 8288 8800 8336 7872 7872 7872 7872 InjDur 08 5000 9024 8896 8656 8384 8032 8176 10000 7120 6064 5856 5504 5168 5168 5168 5168 InjDur 07 5000 9008 8640 8448 8096 8880 8000 7312 7328 5616 5568 5200 5024 5024 5024 5024 InjDur 06 5000 9088 8208 8016 7280 7728 7360 6016 6016 5600 5632 4608 4912 4912 4912 4912 InjDur 05 5000 8256 7632 7072 6976 6816 6352 5312 5936 4768 5600 4528 3856 3856 3856 3856 InjDur 04 5000 6496 6368 6672 5872 5792 5568 4912 5024 4544 4576 3968 3632 3632 3632 3632 InjDur 03 5000 5536 5424 5344 4944 4976 5280 4176 4192 4288 3616 3376 3328 3328 3328 3328 InjDur 02 5000 4880 4608 4320 4784 4368 4384 3296 3200 3728 3680 3488 3280 3280 3280 3280 InjDur 01 4500 4080 3872 3392 3232 2400 2432 2496 2400 2160 1984 1920 1920 1920 1920 1920 InjDur 00 4000 3392 3200 2944 2880 2160 2160 2192 1856 1792 1728 1728 1728 1728 1728 1728 RPM 500 1000 1500 2000 2500 3000 3501 4002 4501 5000 6000 7009 8012 8012 8012 8012 Flags 14 () () () () () () () () () () () () () () () () Flags 13 () () () () () () () () () () () () () () () () Flags 12 () () () () () () () () () () () () () () () () Flags 11 () () () () () () () () () () () () () () () () Flags 10 () () () () () () () () () () () () () () () () Flags 09 () () () () () () () () () () () () () () () () Flags 08 () () () () () () () () () () () () () () () () Flags 07 () () () () () () () () () () () () () () () () Flags 06 () () () () () () () () () () () () () () () () Flags 05 () () () () () () () () () () () () () () () () Flags 04 () () () () () () () () () () () () () () () () Flags 03 () () () () () () () () () () () () () () () () Flags 02 () () () () () () () () () () () () () () () () Flags 01 () () () () () () () () () () () () () () () () Flags 00 (O) (O) (O) (O) (O) (O) (O) (O) (O) (O) (O) (O) (O) (O) (O) (O) Tank You for the answer,i analize and try this map,all suggestion is welcomed!! Tanks pasotibbs!
kadavere Posted November 12, 2008 Posted November 12, 2008 The LC1 is a true good,powerful hardware and software,easy to use,setting,mounting. But the original gauges is too expensive,i made a modify on my optimiser box and circuitry,first a pushbutton with a click feedback,double the third button on the left of the handlebar,change the display with one more great and readable built in a backlight for a night tuning session,i add a simply circuit based on the bottom schematics for read in real time the fast variations of the AFR or LAMBDA output of the LC1.this is more friendly and fast than a number,immediately you understand what happens. The next step is to close the display and bargraph with a sinthaglass,a liquid acrilic glass. Is possible to think to close this in a round gauges from an old bike/car instrument for a permanent installation,for this use you need the power supply on the bottom of the schematics for a good work is better to enclose the diagnostic led of LC1,is not too rare this go on failure state,but if you set a know volt output value for failure state you don't need other led,simply you see only one led of the bargraph fixed,no other work. Be sure to connect ONLY the signal from LC1,the ground is common don't need other connection or maybe you create a dangerous ground loop!!! I used a good microphone shielded cable and waterproof connector from AMP or TICO for external signal wiring and don't have any problem of bad ground connection,only remember to weld the shield only in one side of the connection. I hope my little experience help some guzzi's owner friends.... Kadavere
luhbo Posted November 12, 2008 Posted November 12, 2008 Hi Kadavere, I'm one of those having only pure fun with the MyEcu. I had the My15M Mk1 for 3 years or so, 2008 I finally switched to the Mk2 - also a smooth and flawlessy running unit. I had problems sometimes, but every single time the fault was on my side. Faults can be made in the map (an "O"utch instead of an "0"-Zero e.g. - one of my favorites ), on the PCB (not looking good enough on the schematics when you assemble it) or in the flash or programming process. Once you have these things sorted the easy part begins. Your map shows this: RPM 500 1000 1322 1520 1750 2011 2314 2663 3061 3521 4045 4658 5357 6058 6756 7470 Flags 14 (O0) (O0) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) Flags 13 (O0) (O0) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) and this: MyECU Cfg O2=0.00V,0.00V,0.00V,0.00V,0.00V,0.00V,0.00V,0.00V, MyECU Cfg 2ndO2Sensor=no This could mean you're running the unit in a somewhat open loop. To avoid questions like that write a value into the second and the following cells. Lambda 0.9 will perfectly do. Don't ask how exactly the ECU interprets every single cell of the map, you won't get too much answers The better strategy is to avoid unnecessary questions. If this will not give you better results then download the maps exactly as Cliff had sent them to you and run the MyEcu in "defined" Open Loop mode (using the switch). Don't forget to dial in the correct TPS offset. If this won't work then you have a problem somewhere else. Find it before you proceed. Remember that the +5V at the Optimiser are coming from the MyEcu. I don't think you should hook to much other devices to it. This might negatively affect the CPU (just an idea). BTW, I've heard from some people of having severe problems with the LC1 units. i don't have one myself, so it's pure gossip, but I'd give the open loop idea a try because of that. Also make sure that you have set the TPS according to what the book says (and that you have dialed in the coresponding TPS-offset in the map). Still no success? Then try the diametrically approach: download the original map from Cliff again and set your TPS to reach the offset value which Cliff had sent you with his map. Again try it open and closed loop. Tonight I will post the values for starting up your engine. I don't have them at hand now. Starting actually is a very easy part of the game, you just need to have the proper values in the map. Hubert
kadavere Posted November 12, 2008 Posted November 12, 2008 Hi Kadavere, I'm one of those having only pure fun with the MyEcu. I had the My15M Mk1 for 3 years or so, 2008 I finally switched to the Mk2 - also a smooth and flawlessy running unit. I had problems sometimes, but every single time the fault was on my side. Faults can be made in the map (an "O"utch instead of an "0"-Zero e.g. - one of my favorites ), on the PCB (not looking good enough on the schematics when you assemble it) or in the flash or programming process. Once you have these things sorted the easy part begins. Your map shows this: RPM 500 1000 1322 1520 1750 2011 2314 2663 3061 3521 4045 4658 5357 6058 6756 7470 Flags 14 (O0) (O0) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) Flags 13 (O0) (O0) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) (O1) and this: MyECU Cfg O2=0.00V,0.00V,0.00V,0.00V,0.00V,0.00V,0.00V,0.00V, MyECU Cfg 2ndO2Sensor=no This could mean you're running the unit in a somewhat open loop. To avoid questions like that write a value into the second and the following cells. Lambda 0.9 will perfectly do. Don't ask how exactly the ECU interprets every single cell of the map, you won't get too much answers The better strategy is to avoid unnecessary questions. If this will not give you better results then download the maps exactly as Cliff had sent them to you and run the MyEcu in "defined" Open Loop mode (using the switch). Don't forget to dial in the correct TPS offset. If this won't work then you have a problem somewhere else. Find it before you proceed. Remember that the +5V at the Optimiser are coming from the MyEcu. I don't think you should hook to much other devices to it. This might negatively affect the CPU (just an idea). BTW, I've heard from some people of having severe problems with the LC1 units. i don't have one myself, so it's pure gossip, but I'd give the open loop idea a try because of that. Also make sure that you have set the TPS according to what the book says (and that you have dialed in the coresponding TPS-offset in the map). Still no success? Then try the diametrically approach: download the original map from Cliff again and set your TPS to reach the offset value which Cliff had sent you with his map. Again try it open and closed loop. Tonight I will post the values for starting up your engine. I don't have them at hand now. Starting actually is a very easy part of the game, you just need to have the proper values in the map. Hubert Tank Hubert! I'm happy you have fun with your bike+MyEcu,this is i want for me too! Yes my map don't look so good....this is because before i set on the second O2 cell a value of 2.00V for build a richer map, after,when i run in open loop i delete this value and put 0.00V+ move the switch on ECU Why this?Because i make many night session (night is more safety in Italy,no police on the street i use for test! ) with the original WMP8 and LC1 + led bargraph,i understand this work incredible like an closed loop!! You see the the AFR ratio with some little oscillation in every situation of RPM or load,AFR look around ratio of 13. After many closed loop session in highway and street,i partially clone this on MyEcuP8,now the bike work better than a initial map,in the mix street,fast,curves is funny!! i only have problem with the Idle to Wot to solve. I follow your suggestion about avoid questions!True i don't have to know what MyEcu done inside I have a little background of electronics and before i start to assemble i make a little"reverse engineering"of the schematics and value of the three version of ECU's for be sure don't make a mistake on my assembly.This part of work is crossed with success!Don't be fear,Cliff is smart and for voltage regulator used a well know and strong components,this have a low dropout and able to delivery 1Amperes at 5V. I have the LC1 kit only from 2 months and sincerely the only things of strange i found is that's fall in failure mode if fast you turn ON-OFF the key,but surely to avoid problem need to follow all Innovate suggestions. I control again my settings! Tank for the suggestion Hubert!
luhbo Posted November 12, 2008 Posted November 12, 2008 Yes, take it easy and you'll get the fun you've expected. For starting the engine try out the following values: ---------------------------- # Prime gives the fuel injection time in ms while cranking #Temp C -30 -20 -10 0 10 20 25 30 40 50 60 70 80 90 100 110 125 Prime 50 40 30 30 25 20 20 12 7 5 5 5 # Crank is the % boost of the map injection times right after start # this boost decays to 0 over about 20s #Temp C -30 -20 -10 0 10 20 25 30 40 50 60 70 80 90 100 110 125 Crank 80 70 50 40 30 23 20 15 10 2 0 0 0 0 0 0 ----------------------------------------------------- These lines say what happens while the engine cranks. No further relation to other values in the map. Every time the piston aspirates the ECU gives a 20 ms shot of fuel (at 20 or 25°C), regardless how much throttle you have (use WOT for leaning it out if you think the engine has eventually drowned). At -30°C it would be 50 ms - you see you've got the perfect ECU for Rimini, your average temperature range is covered For me these values work nearly perfect. Just "nearly perfect" only because the OEM ECU is unbeatable when it comes to starting. If you have idle problems then try the following values as bottom line (you are sure that everything else is ok? Valve clearance, rubber sleeves, spark plugs ...) : --------------------- InjDur 00 2672 2848 2512 1936 1616 1104 600 300 200 100 100 100 100 100 100 100 ---------------------- If you have the voltage correction table set to zero you have to add 1000 to each value. Maybe that you need higher or even lower values, just do not make the fault to dial in to much difference between cell 1, 2 and 3. Remember, starting is triggered elsewhere, so there is no need to overly enrich cell 1. This would only drown the engine as soon as it falls below 1000 rpm by some reason. Idle is at 1000, now use the optimiser to achieve a good ARF for this cell and then copy this InjDur-value to the first and third cell and make them a bit leaner to stabilise idle. It's that easy. These lines are probably all you should alter in Cliff's map to achieve a usably running bike. Then adjust the map via Autotune to your needs, but only in small steps. If you actually have it 20 or more percent richer now than there is a good chance that the map has become inconsistent. HTH, Hubert
raz Posted November 12, 2008 Author Posted November 12, 2008 Cool idea with the bar graph LEDs. It never occured to me how simple and cheap that would be. A couple of thoughts: Have you confirmed that your analog LC-1 output match what you see when you read the digital channel? I had some discrepancy (+20 mV offset all over the range) even though my grounding is good, and I compensate for that in my LC-1 voltage settings. The digital outputs will be correct regardless of grounding offsets as long as there is good heater and free air calibrations. On the other hand, if you mimic the voltages you see with the P8, you should be fine. Have you tried datalogging with a computer in a tank bag or something? Maybe Cliff's accel pump emulation combined with a somewhat rich map add up to overly rich when pulling the throttle. A bit like the carburetted 1100 Sport when pinning it - you have to nurse it up to speed if it's not very good tuned, or it will choke on excessive amounts of fuel from the huge carbs.
kadavere Posted November 13, 2008 Posted November 13, 2008 !!!!!!!You have A great baggage of experience!!!!!! I have to start from the beginning my map,what i read in the MyEcu official page make only a confusion in me, now with your and other suggestion i try a different approach that's i never consider before..... I'm too nervous today rain,only rain!!!!Where i try my new map!!!! TANKS!!!!!!!! Ivan
kadavere Posted November 13, 2008 Posted November 13, 2008 LOG.zip HI! For read the digital channel i need the log program from innovate?I try if i have the same offset,the problem for me is the neighbours, in his blood don't flow the passion for the bike,i have to grab my Eee Pc and go in a parking....I'm too curious about this offset!!!! The grounding is perfect,same screw for battery,ECU,LC1,welded not crimped,scratch the varnish and finally apply a special grease used inside a 20KV junctions cable (i'm electrician ) Yes,i make a clone like of the P8,but now i have a doubt,i want to discover the offset ghost! No,i don't logging MyEcu,my friend don't put on my Eee Pc the hyperterminal,when i have sure i log!!! I logged the original WM P8 with a cheaper tool hardware+software i bought from Technoresearch if somebody is interested just for curiosity i send the file of my log,controlled with norton and avira,the program is possible to found here: http://www.technoresearch.com/Downloads/downloads-VDSTS The standard version don't need a dongle.... Your idea about the motor choked is a way to follow,before i think diametrically opposed,maybe blind from high output value from LC1 and counseil from a rally car driver..... Tanks,immediately after the rain stop i try!!! Ivan
greenmonster Posted November 13, 2008 Posted November 13, 2008 Nice idea w LEDs! I logged the original WM P8 with a cheaper tool hardware+software i bought from Technoresearch if somebody is interested just forcuriosity i send the file of my log,controlled with norton and avira,the program is possible to found here: http://www.technoresearch.com/Downloads/downloads-VDSTS The standard version don't need a dongle.... Interesting. How did you connent PC to WM P8? +1 on luhbo, go nice & easy from start, first things first.
kadavere Posted November 13, 2008 Posted November 13, 2008 Nice idea w LEDs! Interesting. How did you connent PC to WM P8? +1 on luhbo, go nice & easy from start, first things first. The interface is a cable,one end fitted with a AMP 3 poles connector and a fast connection for the battery poles,this is the ECU side, in the center,sealed,the electronics,i imagine a microprocessor used like a dongle and a few component for translate the voltage level,but i never open,the other end have a 9 poles standard serial connector,i use a 9poles to usb converter..... The sistem work good with a little Eee PC,i put this in the left suitcase and when come back i have my logging. In the picture you see the little black suitcase,inside,visible, the cable and the software CD,the Eee PC is little but friendly object for this use, the box connected is the USB converter + Cliff TTL to RS232 converter,on the bike you see MyEcu fitted in a WM case,not the original!!! I don't destroy the P8 for nothing at world!!This ECU is too rare,in Italy too,is more than a ECU,is very sophisticaded,in the past used on Sierra Cossworth and Lancia Delta Integrale,full capable of diagnostic for every pheriferial..... The question now born....if you like too much the original,why bought MyEcu?...Simple,first i need a second ECU when in the summer i make my journey outside Italy (in the suitcase:1KG oil,throttle and friction wires,tools,tyres repair kit,relais,bulb,now ECU),second MyECU is too cheap,if you want to buy a software for Eprom analisis and programming minimum need 500-800 euros!!(only one ECU) Third,if is possible to make a better feeling with the motor is better in this picture the LC1 cable and pheriferial box,the box is filled whit a special gel i use for submersed electrical junctions,no humidity inside The curious violet and white round object on the right side is an "absolute air filter"(a spare of air compressor i use for homebrewing) fitted on the pressure sensor inlet,before this was connected directly to airbox,but im not satisfied about the continous change of the original WM ECU,after i make this modify this be stable!!
kadavere Posted November 13, 2008 Posted November 13, 2008 For me these values work nearly perfect. Just "nearly perfect" only because the OEM ECU is unbeatable when it comes to starting. If you are couriuos what happens in the OEM ECU when it come to starting i made a log!!!!!! In my other message you found the .Zip file and the coordinates for find the program for read.
luhbo Posted November 13, 2008 Posted November 13, 2008 I'll have a look at this log file. That's some great information. Actually you've been the first here and elsewhere who was able to provide some information of what the OEM units do. Thanks for that. Hubert
greenmonster Posted November 13, 2008 Posted November 13, 2008 Is the VDSTS really freeware? Many options were locked for me when I opened it. Can it read your log files which seems to be .text files, not .log files?
kadavere Posted November 13, 2008 Posted November 13, 2008 Is the VDSTS really freeware? Many options were locked for me when I opened it.Can it read your log files which seems to be .text files, not .log files? Yes because for unlocking the principal function you need the interface,like a dongle,but for read the .log files i send you have to go in the "graphical page"and after load the file,few seconds and you see what my OEM ECU tell!!! Is clear the many WOT i made!!!!
kadavere Posted November 13, 2008 Posted November 13, 2008 I'll have a look at this log file. That's some great information. Actually you've been the first here and elsewhere who was able to provide some information of what the OEM units do. Thanks for that. Hubert All is possible for me to share i send!!!!!! Again rain......i wait for try new settings....
