Hey y'all,
I just noticed today that when I come to a sto and get to just under 20mph my front brake shudders. very noticeable. i checked the pads and they are very good.
Got any ideas?
Fred
I assume it's the front brakes that are giving the problems.
Check the discs for warpage, possibly caused by overheating. A good way to tell is look for any discolourations (blueing). More accurate method is using a dial gauge to check for Flatness....is that a word??
Also check to make sure the caliper and disk fasteners are tightened to the appropiate torque specs.
Hope that helps a bit.
Raceboy
The rotors are "semi-floating." Which means they semi "do not" float. Lubricate the buttons with a penetrating oil like Break-Free CLP and tap the rotor around a bit with a mallet. Wipe off any excess oil and see if the shuddering doesn't improve.
Consider , also, cleaning the pads with a good brake cleaner and bleed the system well.
take the pads right out of the caliper and check and clean. I had a pad seperate from its backing plate and cause a terrible vibration but could not see it until I removed the pads
This is what worked for me. I used a square plumbing tool to rotate the buttons when I lubricated them. Check them all.
Well I took the pads out and cleaned them with brake cleaner. Reinstalled and no shudder. Musta had some gunk on a pad. Thanks for all the advice.
Fred
