Hiya, came across these recalls. Note "death" being mentioned.
Being from Singapore, I am wondering how do I go about doing this; it has been a while!!!!
2000 Moto Guzzi V11 Sport Recall
NHTSA Campaign ID Number: 03V487000
Recall Date: Nov 24, 2003
Component: Engine And Engine Cooling
Potential Number Of Units Affected: 64
Summary: On certain motorcycles, under extended running speeds near the engines revolution limit, the engines connecting rod bolts can fail. Consequence: should such a failure occur, the motorcycles engine can suddenly stop turning or lock, requiring the operator to disengage the clutch in order to maintain control of the motorcycle. If the clutch is not disengaged, the operator can lose of control of the motorcycle, which could result in a crash, personal injury, or death.
Remedy: Dealers will install new, redesigned connecting rods and bolts. Owner notification is expected to begin during December 2003. Owners should contact Moto Guzzi at 1-877-aprilia (1-877-277-4542).
Notes: Moto Guzzi Recall No. 101EAS. Customers can also contact the National Highway Traffic Safety Administration's Auto Safety Hotline at 1-888-DASH-2-DOT (1-888-327-4236).
2000 - 2001 Moto Guzzi V11 Sport Recall
NHTSA Campaign ID Number: 03V486000
Recall Date: November 24, 2003
Component: Transmission
Potential Number Of Units Affected: 680
Summary: On certain motorcycles, the gearbox shift sleeves for engagement of 3rd to 6th gears can fracture unexpectedly while the motorcycle is in use.
Consequence: should such a fracture occur, the motorcycle's rear wheel can suddenly stop turning or lock, resulting in a loss of control of the motorcycle, which could result in a crash, personal injury, or death.
Remedy: Dealers will install new, improved shift rings and a redesigned cush-drive assembly. Owner notification is expected to begin during December 2003. Owners should contact Moto Guzzi at 1-877-aprilia (1-877-277-4542).
Notes: Moto Guzzi recall No. 101EBS. Customers can also contact the National Highway Traffic Safety Administration's Auto Safety Hotline at 1-888-DASH-2-DOT (1-888-327-4236).
SK, these recalls have been covered extensively here many years ago, and periodically ever since.
My '00 Sport was part of the trans recall (not the con rod/bolt recall). I had a local Guzzi dealer (Moto GP) do the recall work. I brought them the box, Dave did the authorized part replacements and signed it off in a couple of hours.
To my knowledge, no catastrophic failures of any kind have been documented having to do with either recall -- let alone "death". :rolleyes:
Since the recalls you noted above are for 2000 and 2000-2001 Guzzi's, and yours is a 2002, in your case, it would seem that unless you want to stretch a considerable ways past any logical reason for stuff to worry about, there's not a thing to do. . . :huh2:
