Slavomir Musilek (R.I.P.) Posted September 22, 2008 Posted September 22, 2008 hm... after replacing shift springs I suffer heavy oil leaks from g box. It leaks heavilly from the bolt up to neutral switch. Is there any way to get rid of it? I am thinking about silicon but wanted to ask first... oil is dripping directly on to the x-over and it smells just
Greg Field Posted September 22, 2008 Posted September 22, 2008 There's supposed to be al aluminum crush washer under the neutral switch. Change that out first.
Slavomir Musilek (R.I.P.) Posted September 23, 2008 Author Posted September 23, 2008 There's supposed to be al aluminum crush washer under the neutral switch. Change that out first. neutral switch is ok... oil is dripping from bolt above
Greg Field Posted September 23, 2008 Posted September 23, 2008 Sounds like you will have to remove the cover and re-seal it. Use Permatex anaerobic sealer.
