TPS adjustment
Guest jimjib
Where is the easy place to check the tps reading? The way the connector is positioned, makes it almost impossible to get the probes on the terminals.
Guest hyper
Jimjib, my voltmeter has an end that goes around the wire, you lock it in position and when you clamp it ,it pricks through the plastic and into the wire. Since most people don't have professional tools I would sharpen the ends and lightly poke through the wires at the tps from the bottom.
Good luck. Hyper
Guest jimjib
I was hoping that there was another convenient plase to get on to it. I think I will get some probes like you have.
