max scura Posted October 11, 2008 Posted October 11, 2008 Hi,I have a problem for my V11 Scura,I need a plexiglass for my carbon winshiled,is there the original or after-market part? where can I buy it ? Thanks a lot Max
macguzzi Posted October 11, 2008 Posted October 11, 2008 Guzzi being Guzzi the screen on that carbon is different to the one on the standard the holes are in different places for no reason but we can make them that way just to @#!#$# you up. I don't know where you can get one I've been trying for two years
max scura Posted October 11, 2008 Author Posted October 11, 2008 Have you tried Gustafson(sp) ? I have seen.....too expansive for a plexi.....
Steve G. Posted October 11, 2008 Posted October 11, 2008 I'm in the business. Go to a wholesale plexi outlet, or a glass shop. Look for marguard lexan, not plexi. Lexan is highly resistant to cracking, a problem you will have when you drill the holes for the bolts, or if you tighten the bolts too tight. Do NOT get anything thicker than 2mm thick, 1.5 mm is best. The thicker the lexan, the harder it will be to bend into the shape you want. Marguard is a special surface available on some lexans [ helmet visors] to vastly reduce the collective minute scratches that will eventually make the screen ugly. Try to avoid using heat to shape the lexan/plexi. They use special press molds on pre shaped ones. A hair drier or heat gun will almost always bugger the surface up. That's why 2mm or less is best, the mini fairing will hold it in shape. Steve
Greg Field Posted October 12, 2008 Posted October 12, 2008 I'm 90 percent sure I have this shield on the shelf at Moto Intl. If not, I know where one ir.
orangeokie Posted October 12, 2008 Posted October 12, 2008 The last two posts from Steve and Greg is why this forum is so valuable. Where else can you get instant information about an obscure need for the collectible V11 LeMans.
Greg Field Posted October 15, 2008 Posted October 15, 2008 I do have one in stock. Retail is about $85.
max scura Posted October 15, 2008 Author Posted October 15, 2008 I have found the original one in Mandello...... Thanks for all !!!
