stucatz Posted October 15, 2008 Share Posted October 15, 2008 I cannot seem to have the neutral light, when in neutral of course, come on. And when in neutral, if the kickstand is down, the engine shuts down. So starting the bike I must be sitting on it, with the kickstand up, no neutral light. Is it just the sensor switch? Bike is a 2000 V11 Sport Thanks Link to comment Share on other sites More sharing options...
gstallons Posted October 15, 2008 Share Posted October 15, 2008 Disconnect the wire at the neutral switch, turn the key on, ground the wire to a good ground and look to see if the light is "on". It should be. If so, remove the switch, and clean it with electrical contact cleaner. DO remember to plug the hole where the switch was or you will have gearbox oil running out . Link to comment Share on other sites More sharing options...
stucatz Posted October 17, 2008 Author Share Posted October 17, 2008 Disconnect the wire at the neutral switch, turn the key on, ground the wire to a good ground and look to see if the light is "on". It should be. If so, remove the switch, and clean it with electrical contact cleaner. DO remember to plug the hole where the switch was or you will have gearbox oil running out . Thanks gs, will tackle this week-end Link to comment Share on other sites More sharing options...
gstallons Posted October 17, 2008 Share Posted October 17, 2008 You will not be able to "see" a result as you clean,just spray and work the stem in and out while you are spraying the cleaner. Link to comment Share on other sites More sharing options...
stucatz Posted November 2, 2008 Author Share Posted November 2, 2008 Well I finally got around to this minor yet annoyance on the bike and thanks to gstallions for the info which is exactly what it was. However, due to my persistance at the local gym, I managed to "snap" the bolt clean off,F#!k! For those of you that don't know, it is a hollow bolt with a plunger. So drained the entire gearbox and have sent an email to MG Cycle to see if they have the part. I guess in the meantime I can run it with a suitable bolt in place. Thanks again gs. Link to comment Share on other sites More sharing options...
docc Posted November 2, 2008 Share Posted November 2, 2008 I'm glad I'm not the only one afflicted by over-torquing. Seems to happen to me all the time. Many have reported that Redline in the gearbox helps keep the neutral switch free. Link to comment Share on other sites More sharing options...
